BOTH SPEEDO SLOW AND STICKING
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=17964
Printed Date: November-18-2024 at 4:42pm
Topic: BOTH SPEEDO SLOW AND STICKING
Posted By: QUEBEC
Subject: BOTH SPEEDO SLOW AND STICKING
Date Posted: June-08-2010 at 10:26am
Hey guy's both my front speedos on my BFN are slow to respond and sticking at slow speeds and won't drop to zero even with lines off. but seem to read ok at speeds of 35 to 49 mph. Any tricks like lube speedo heads or something. boat was sitting for 10 year's
------------- NEVER EVER GIVE UP ON YOUR SELF YOUR FAMILY YOUR FRIENDS AND GOD THERE ALWAYS A NEW DAY
Date Posted: June-08-2010 at 10:58am
John,
The only way to really tell what's going on is to take a look inside. There may be some congealed grease on the rack/pinion gears. They however may free up with use.
Posted By: gn6027
Date Posted: June-09-2010 at 11:03am
Same thing happens to me occassionally. Sounds like a plugged pitot tube(s). Try cleaning out the inlet to the pitot tubes using a paper clip or safety pin.
Cleaning always does the trick for me.
Glen
------------- GN6027
http://www.correctcraftfan.com/diaries/details.asp?ID=2562 - 1987 Ski Nautique 2001
Posted By: QUEBEC
Date Posted: June-10-2010 at 2:14am
So I will clean the old grease off the rack/pinion gear in the speedo and check the pickup and tubes. what kind of grease do they use to lube them.
Date Posted: June-10-2010 at 8:47am
John,
A very light application of thin (NLGI #1) silicone based grease would be ideal. It's not going to dry up and get sticky but finding it may be a problem. However, dielectric grease is the same stuff. You can get a small tube of it at the auto supply if you don't already have some. You should have some around anyway for when you're doing any electrical work on the boat. Report back when you get inside the speedos.
Posted By: QUEBEC
Date Posted: June-12-2010 at 1:05am
Ok cleaned and lube speedo's today set them at the lake. used wd40 and some air and blew off all the hardware to clean them, then used clock lube used to lube moving parts on old clocks. WOW work better then new so smooth.
Posted By: MartyMabe
Date Posted: June-12-2010 at 1:25am
Great Job
I just might do mine now
------------- 66 Skylark http://www.correctcraftfan.com/diaries/details.asp?ID=5041" rel="nofollow - 93 SN If you're not living in NC, you're just camping out!
Date Posted: June-12-2010 at 9:25am
John,
I'm glad it worked out for you.
