Flood, Foam, and Advice
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=18005
Printed Date: November-18-2024 at 2:40pm
Topic: Flood, Foam, and Advice
Posted By: skfitz
Subject: Flood, Foam, and Advice
Date Posted: June-11-2010 at 7:29pm
There was a flood at my lake this week. The water came up about 6'. The next door neighbor floated my 75 SN out of the boathouse and tied it off so that it didn't destroy the boathouse by floating in it. That was very kind of him, but my boat hangs without the bottom plug in it. I guess I don't have to explain the rest... It could have been worse: there were quite a few $70K boats bobbing down the lake towards certain death going over the dam.
My boat is back on the lift and supposedly drained. The flood water was muddy and silty. Apparently the swim platform never went below the water surface, but the floor was wet (it was raining though). Beyond that, I don't know a whole lot at this point.
My main concern is that the water level rose as high as the starter and silted its insides. Maybe the same issues with control cables. What else should I be looking for when I head out there this weekend?
Note: I had planned to re-string the boat in the next couple of years and the plan was to do it sans foam. If my boat had been foam-free this week, I'd be limited to collecting an insurance check. Hmmmm.
Posted By: horkn
Date Posted: June-11-2010 at 8:14pm
That's too bad. Your neighbor really was trying to help. It's too bad that things didn't go as he planned it.
I wouldn't necessarily assume that a foam less boat won't float. Plywood is pretty buoyant.
I would try and dry it out as much as possible. Maybe even get something to dry it out.
Date Posted: June-11-2010 at 8:24pm
Shawn,
If you feel the starter is the only thing affected, you're lucky. Yes, your neighbor did a good deed.
Pull the starter ASAP and open it up. Clean the insides, blow it out and regrease the bushings. It should be fine.
Do pull both the trans and engine dip sticks and check for water. Then, keep a eye on them.
Posted By: skfitz
Date Posted: June-11-2010 at 11:58pm
Thanks Pete. Starter tear-down is how I'll spend an afternoon this weekend.
I hadn't even thought of the fluids, but it makes perfect sense: if the water topped the dipstick tubes, it could have penetrated from above.
By the way, my neighbor did me a huge favor. In fact, he'd have been doing me a favor to scuttle the boat rather than let it float up and trash the boathouse.
Posted By: skfitz
Date Posted: June-12-2010 at 1:17pm
OK, I was lucky. Here's a sample of what it looks like here.
Posted By: horkn
Date Posted: June-12-2010 at 1:40pm
HOLY CRAP!!!!!
You were totally lucky. That sport nautique looks to be unscathed, but only because the roof didn't collapse from the pontoon.
Looks like those pics were taken from a boarding boat. Did someone else get lucky too?
Posted By: skfitz
Date Posted: June-12-2010 at 2:26pm
Originally posted by horkn horkn wrote:
HOLY CRAP!!!!!
The Sport needs a new windshield, at least. It, like all the others, floated to the boathouse ceiling and bashed against it for a few hours, totally submerged.
These photos are pretty representative of the carnage, but there are a number of people who live there full time. Most of those folks did OK because all you really need to do is float your boat while the water rises and falls, and push away the boats, houses, trees and garbage that came blasting down.
Lake is officially closed 'till after the 4th.
Date Posted: June-12-2010 at 5:00pm
Shawn,
Are there other pictures? You mention "boathouses" and all I see are covered slips. Is that what you call a boathouse down there?
Posted By: WakeSlayer
Date Posted: June-12-2010 at 5:07pm
That Sport is going to be in tough shape... motor underwater for hours, and untouched since it came up....   ouch.
Mike N
1968 Mustang
Posted By: daddyo
Date Posted: June-12-2010 at 5:22pm
That's horrible. Lake Mcqueeney?
Posted By: skfitz
Date Posted: June-12-2010 at 8:38pm
Yeah, McQueeney. Dunlap and Placid look like that too.
Pete: Down here, if it has a lift and a roof, it's a boathouse. Most have a concrete patio deck on top, and almost all are built on oilfield well casings. The boat cradle is suspended from above. Almost none have sides, and the reason, well . . . When my in-laws first bought a place out there, there were mainly just fishing cabins and modest weekend places on the lake. Boathouses had sides back then and were built on wood poles. It's a constant level lake, but it's a small lake. So small that every third year or so, heavy rains raise the water level a couple feet.   Then there was a huge flood in 1972, and boathouses with walls fell to the hydraulic pressure of the current and the wood structures snapped. So there's your explanation for the colloquial use of "boathouse."
Subsequently, there have been huge floods (+/-500 year) in 1998 and 2002. This was probably a mere 100 year flood. lol. Crazy thing is that property values have risen by about 500% since '95 or so . . .
Posted By: GottaSki
Date Posted: June-13-2010 at 12:03am
Crazy. looks like you did ok.
Although there are foam skeptics here, i believe nobody has recommended rebuilding without a flotation system.
River Rat to Mole
Posted By: Air206
Date Posted: June-13-2010 at 1:34am
Really? Cool!
Folks have other non-foam flotation systems? You mean air? Or something else............?
https://tinyurl.com/y6t5e3bu" rel="nofollow - 04 Air206
http://tinyurl.com/9urzgls" rel="nofollow - 91 Barefoot
78 SkiTiq
Posted By: horkn
Date Posted: June-13-2010 at 3:08am
Really? Cool!
Wood....
Date Posted: June-13-2010 at 9:51am
This is correct at least with my comments. I've always suggested getting more foam in under decks just don't put it back in the bilge! However, with a carefully done stringer job with epoxy, there's really no reason foam can't go back in the bilge.
Posted By: Air206
Date Posted: June-13-2010 at 11:47am
Really? Cool!
Wood....
    Ha!
78 SkiTiq
Posted By: Keeganino
Date Posted: June-13-2010 at 9:03pm
What a nightmare! My 73 skier has 2 large blocks of styrofoam glassed to the underside of the deck. I am only refoaming up in the front where the stringers end in the box. The cavities outside of my bilge will be completely sealed with epoxy and short of a breach in the hull should provide plenty of buoyancy in a flood situation. I like the idea of packing empty 2 liter bottles with the caps on into the cavities too.
