Different engine combos and power
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=18257
Printed Date: April-14-2025 at 11:33pm
Topic: Different engine combos and power
Posted By: skyway2k
Subject: Different engine combos and power
Date Posted: June-29-2010 at 9:12pm
Guys,
I'm getting very close on finishing my search for my own Nautique and one thing I've always had in the back of my mind is the different engines out there for the various years. Ever since I was about 10 years old, I've been in love with the 90-93 era Ski Nautiques and that is how I started out my search. However, I branched out and was very close to buying a 96 Signature Edition before someone swiped it out from underneath me.
I don't know what it is, but it has to be the lines of the 90-93 with the solid color down the side, the more sharp outlines of the windshield than the 94-96, especially the one piece front class with no frame bar in the center. Gorgeous.
BUT - I've noticed huge advancements in power as the years go up. I believe the 90-93's I've seen mostly have the 240 HP engine, and they go on up to like 310 with the GT-40 with the later years up to 96. My question is, how much do you really notice this difference when you're out boating? It's not like you're towing balls out WOT the whole day, so is it really that big of a deal? And besides, the more I think about it, the more I'm attracted to the simple mechanical fuel pump and carburetor. EFI and more electric components are just more expensive crap to go bad in my book.
Any thoughts?? I'm closing in on one 91, and one 92 as a backup.
Thanks everyone.
Posted By: Bigcity
Date Posted: June-29-2010 at 9:59pm
I bought my 1994 CB ski with carbed base 351/ 240hp 3 seasons ago and had the same concerns as I was used to GT40 power.
Since then I have been slowing accumulating the High performance upgrade parts including GT40P heads, custom grind cam and Edelbrock intake for a future rebuild.
The best upgrade tip I picked up from the guru's on this site was prop and I installed a Acme 540 last season. The boat is a rcoket out off the hole and can not be touched 0-40.
If it ain't broke don't fix it.
1993 onward no wood!!!
BIGCITY
/diaries/details.asp?ID=2564 - My Baby !!
Posted By: 87BFN owner
Date Posted: June-29-2010 at 10:52pm
Skyway2k
The power will or will not be missed based on your use of the boat. What is your primary use for the boat going to be?
Posted By: skyway2k
Date Posted: June-29-2010 at 10:57pm
I have two brothers that ski, one used to like to barefoot, the other slalom skiing. I would like to learn to ski, all types, as we got rid of our Ski Tique back when I was very young. The other uses would be *gasp*... tubing with friends who don't know how to ski.
Posted By: SN206
Date Posted: June-30-2010 at 12:06am
I vote GT-40. I think it was one of if not the best block built. I miss mine.
Posted By: skyway2k
Date Posted: June-30-2010 at 12:20am
So does the GT-40 have a different block than the 351W? I thought it was just different top end?
Posted By: kapla
Date Posted: June-30-2010 at 12:43am
its a 351w
in the year range you are looking 90-93 you can get a boat with the proboss engine rated 285hp...generally speaking its a carbed gt40....
though i'm not sure which year it started as an option
<a href="">1992 ski nautique
Posted By: skyway2k
Date Posted: June-30-2010 at 12:50am
I'm 99% done on a deal for a 91 Yellow and Black... awesome looking boat. I'm sure I won't be disappointed either way. Maybe some day down the road, I can upgrade to a more powerful boat if need be.
Date Posted: June-30-2010 at 1:35am
No need to change the boat for more power. Plenty of upgrades to be done on the 351W to make more power.
Posted By: skyway2k
Date Posted: June-30-2010 at 1:37am
Thanks for all the replies... I can't wait to pick her up Thursday!! :)
Date Posted: June-30-2010 at 1:16pm
There were no EFI options for 1990-1993. The TBI version of the 351w (both standard and HO) was available 94-95, the GT40 multiport EFI based on the HO 351w debuted in '95.
The Protec distributorless ignition was introduced in '91 and is known to be somewhat problematic, so be aware that most '91-93 boats (both standard and HO 351w's) will have that. Its about a $500 conversion to go back to a conventional distributor.
As far as the engines themselves go, there were basically 2 flavors- the 240/255hp "standard" version of the 351w, and the "High Output" ProBoss 351w, rated between 285-300hp, which was introduced in 1992. These hulls perform really well with the HO, and can run in the upper 40's (46-48mph) in stock form. Depending on how fast of a hull you have (I have a slow one- they all pop out of the mold slightly different), top speed with the standard motor will be in the low 40's (41-44, generally). The base motor is plenty sufficient for just about any use, save for high speed barefooting (multiple footers, one foots, etc).
Like 87bfn said, its not a hard or overly expensive job to upgrade the base 351w for more power. $1500 in proven parts will upgrade the top end of the motor and make it good for ~320hp, and outrun even the HO boats. I went just a tad beyond that with an exhaust and other upgrades, but now run a reliable 47mph on my slow hulled '90, and there arent many boats that will keep up with it out of the hole.
Like you, I grew up with a few 1990-1993 era boats (namely my dad's red/black '92) and absolutely love the look of the bold stripes, slanted back and pointed nose. I have a tough time picking a favorite CC, but Id have to say that this is the best looking.
I love the yellow/black- my uncle has a '90 in those colors. Post some pics once you pick it up!
Posted By: mdvalant
Date Posted: June-30-2010 at 2:36pm
Hard not to agree with you, TR ;)
http://www.correctcraftfan.com/diaries/details.asp?ID=5009 - '90 Ski (sold)
http://www.correctcraftfan.com/diaries/details.asp?ID=5479 - '00 Sport
Mississippi River - Bellevue, IA
Posted By: horkn
Date Posted: June-30-2010 at 3:45pm
Nope, same block. Different heads, easy swap. GT40P heads are even better than the GT40 heads that came on the boat.
My boat had 240 hp previously, and I put on GT40p heads, and an edelbrock performer intake. It feels like it has more power to me, but I have yet to do a top speed run yet, oratempt a heavy pull of several skiers since the swap.
I put on an acme CNC prop shortly after I got it,and even with 240 hp, it pulled very well. Better than newer nautiques and moombas with over 300 hp.
Posted By: kapla
Date Posted: June-30-2010 at 4:21pm
nice chevelle back there mike...nice combo..
Posted By: mdvalant
Date Posted: June-30-2010 at 4:25pm
Wish I could say it's mine Kap ;)
Posted By: kapla
Date Posted: June-30-2010 at 6:43pm
nice boat then...
Posted By: coach'80
Date Posted: July-02-2010 at 10:00pm
so if i am having a rebuild done on my 351W I should not have them rebuild the heads and purchase GT-40P heads to go on it?
1980 Ski new project
1994 Ski (sold)
Posted By: coach'80
so if i am having a rebuild done on my 1980 351W I should not have them rebuild the heads and purchase GT-40P heads to go on it?
1994 Ski (sold)
Posted By: Gary S
Date Posted: July-03-2010 at 1:55am
Depends on what you want your engine to do.Ask the rebuilder how much to redo yours. If you go with a quality job,new guides,new springs,maybe replace a few valves,surface them, you might be real close or more than the 598 for gt40p's
Posted By: coach'80
Date Posted: July-03-2010 at 2:51am
where can I get them for $598?
1994 Ski (sold)
Posted By: horkn
Date Posted: July-03-2010 at 1:08pm
Tri state does
http://www.tristatecylinderhead.com/catalog/product_info.php?products_id=40&osCsid=fc3ca107a4bf0c9235575bbf216a7f47
GT40p's definitely give the boat a boost in power versus the stock 240 hp heads. I had good power with the acme prop with the stock motor, but it goes a lot better with the gt40ps and the different intake on it.
Posted By: skicat2001
Date Posted: July-03-2010 at 10:08pm
I am saving my money for a 390 Ford.. I hope I can find one when I am ready...
1985 CC 2001-SOLD
Lee Michael Johnson
Posted By: horkn
Date Posted: July-04-2010 at 1:26am
I think the exhaust manifolds are different enough that a 302 351w exhaust manifolds won't fit onto a FE. Those FE series motors are a very wide motor. Even if you could find a set of manifolds that will work for a boat, they likely would not fit under the motorbox without a lot of work to modify the box to make it wider.
You would be better off with a 460. Those have been marinized before. I don't think I have ever seen an FE that's been marinized.
Date Posted: July-04-2010 at 9:58pm
Hey Tom,
Really? Cool.. I will have to think about that. I would really not want to change much, just to another big block ford. Thanks for the advice..
1985 CC 2001-SOLD
Lee Michael Johnson
Posted By: horkn
Date Posted: July-04-2010 at 11:04pm
fwiw, you can build up a 351 to a stroked beast if you want.
It would be easier and cheaper to build up the W than put in a different motor.
Date Posted: July-06-2010 at 10:14am
And you are the "self proclaimed" Ford expert!! Where were you in the 60's????? We even have CCfan members with FE engines!
Posted By: 79nautique
Date Posted: July-06-2010 at 12:37pm
DA is what I recall, besides isn't the exhaust on the FE the exact same as the 460.
Posted By: JoeinNY
Date Posted: July-06-2010 at 12:50pm
While I agree that it would be easier and cheaper to build up the 351w if you already have one than to switch to a 390 the FE block was as these guys state a fairly common marinization. Both engine platforms are common enough with enough marine and performance parts available that I can't see much reason to ever switch from one to another.. a situation where staying original will keep your money going where it should.. more power and reliablity.. and not where you'll never notice it like towards new alternator brackets, starters, engine mounts, and other assorted bits.
http://www.correctcraftfan.com/diaries/details.asp?ID=1477 - 1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Date Posted: July-06-2010 at 1:19pm
Chris,
I don't feel they use the same manifolds. The FE's were the 352,390 and the 427
Posted By: horkn
Date Posted: July-06-2010 at 2:14pm
They don't use the same manifolds.
I'm glad someone very nicely informed me that there were FE's that were marinized, and even used by CC.
Good luck trying to find a set of manifolds for a FE though.
Date Posted: July-06-2010 at 2:33pm
Luck?? http://barrmarine.net/wordpress/interceptor-v8-2/ - 352,390 and 427 manifolds
Date Posted: July-06-2010 at 2:35pm
Would you like the link to the web site to buy new polish header style manifolds, DA they have been available for over ten years and counting.
damn Pete that's not even the site I was referring too you mean they have more than one option to source who would have known
Posted By: horkn
Date Posted: July-06-2010 at 2:39pm
Good, they are available then. He still would be better off building up his Windsor.
Posted By: JoeinNY
Date Posted: July-06-2010 at 2:40pm
Granted it is going to hurt the wallet but they are out there, glenwood marine would be a source for new ones.. Reid and Matt over at race city marine are dealers (as maybe others but they are the ones I know for sure) and last I know go2marine.com had some available as well. A few weeks ago Reidp was quoting me an article talking about relatively low dollar FE stroker kits and short blocks so I have had my eyes on a few things lately just in case I was ever to see a 352 powered boat go by..
Date Posted: July-06-2010 at 2:44pm
http://www.boatdesigns.com/Ford-Header-Type-Exhaust-Manifolds-Pair/productinfo/90%2D959/ - Glen-L polished aluminum header style logs
Posted By: 75 Tique
Date Posted: July-06-2010 at 3:17pm
or maybe on http://cgi.ebay.com/ebaymotors/Glenwood-Manifolds-FE-V-drive-Jet-Flatbottom-Boat-_W0QQcmdZViewItemQQhashZitem2306eaece1QQitemZ150439914721QQptZBoatQ5fPartsQ5fAccessoriesQ5fGear - ebay for a good price.
Date Posted: July-06-2010 at 7:42pm
Good info guys.. When I get ready to buy one, I am looking for a more easy to transform over to another big block ford. Where I dont have to do a complete overhaul on everything. Keep it orginal for the better part, and keep it reliable. Just add more bone stock power, from like a 351 versus a 460.. Add maybe a few things here and there, but making the boat do 70 is not in my ballpark. But if as some of you say, I love the 351 Ford PCM. It is a really good and strong motor. If bumping up is too difficult and ingnorant, I will just stick with what I got.
1985 CC 2001-SOLD
Lee Michael Johnson
