226 fuses
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=18334
Printed Date: November-18-2024 at 4:37pm
Topic: 226 fuses
Posted By: doug19
Subject: 226 fuses
Date Posted: July-04-2010 at 3:52pm
2006 226, the horn was intermittent last year and the power feed to the centre ballast pump is dead. Now both horn & pump feed are dead. Other pump feeds are fine, and have switched them onto the centre pump which itself is fine. Circuit breakers under the dash are all good. There is a fuse panel at rear with the switch for the batteries but can't see how to remove any item. Ideas? Brute strength worries me.
Also, any tips for unscrewing an immovable waterstrainer? I suspect it has never been taken off (70 hours on a clean lake), the bracket is not firm and again I'm concerned about too much leverage. How about an oil filter 'spanner'?
Old enough to know better
