Cleaning Gas Tank
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=18459
Printed Date: November-18-2024 at 5:40pm
Topic: Cleaning Gas Tank
Posted By: Keeganino
Subject: Cleaning Gas Tank
Date Posted: July-10-2010 at 2:10pm
When I took my boat apart in January I siphoned most of the gas out of my tank, then it sat for about 2 weeks on the porch with a little bit of fuel still in there before I taped up all the holes. WHen I started messing with it the other day to put it back in there is something rolling around in there. Maybe my daughter threw a rock or BB in there I dont know, but I figure I need to dump the rest of the fuel and hopefully whatever crap is in there.
So my question is- What should I use to rinse it out if the foreign object does not come out with the little bit of fuel? I have an aluminum tank. I searched a while on fuel tanks and it seems like a good idea to clean the anti siphon valve while I am in there. I have a haz mat dump station near my house so I can dispose of it properly. Any other maintenance I should perform on the tank before installation?
Posted By: DrCC
Date Posted: July-10-2010 at 2:19pm
Take the sender out and shake.   I've found all kinds of neat stuff in gas tanks.
AT
Posted By: FrankT
Date Posted: July-10-2010 at 3:20pm
As the Dr. noted remove the sender so you can look inside. For as much gas in in there you can just pour it on an impervious surface and let it evaporate. I just washed mine out with a high pressure water spray, rinsed several times and air dried with compressed air. You might be suprised what comes out. I do not have a siphon valve and don't know what purpose it serves. My tank sat for 10 years and I had some problems with the screen on the draw tube getting blocked. I have taken this out and am using an inline filter to catch any residual gunk. Mine is galvanized not the aluminum you have. Yours should have an infinite life.
FrankT
Date Posted: July-10-2010 at 3:44pm
Originally posted by Keeganino Keeganino wrote:
   Maybe my daughter threw a rock or BB in there I don't know,
Keegan,
Ha! Kids!! My son was very young and outside helping dad. I had just finished pouring a concrete base for a large yard light. It was a dirt pour except for the top at which I had made a sheet metal form sort of like a spring form cheese cake pan that was held together with nuts and bolts. I turned my back on him for a minute and he had taken the just removed nuts and put then down the 1/2" 90 degree conduit that I had placed in the concrete pad to fish the electric through. Damn, the nut's were wedged in and locked up inside that pipe. It took me several hours to get them out. High pressure water, compressed air while using the fish tape!! But kids do do amazing thins at times!
Yes, I concur with pulling the sender and taking a look inside. Look for white rust (aluminum oxide) on the inside. Tell us what you find. A acid etch may be needed.
Date Posted: July-10-2010 at 3:50pm
Thanks guys. I will let you know what I find.
Posted By: behindpropeller
Date Posted: July-10-2010 at 4:39pm
Some BB's and MEK.
Tim
Posted By: DrCC
Date Posted: July-10-2010 at 7:55pm
Eeek!   I wouldn't use any kind of acid in an old aluminum fuel tank.
Maybe penetrating oil.
AT
Date Posted: July-10-2010 at 8:01pm
AT
Al,
Why not? The aluminum tanks are always of a heavy gauge and decent welding. I've used the acid etch on old tern (or galv) plate tanks as well and then used the coating on them. Very common with the restorations where originality is key.
Date Posted: July-10-2010 at 8:11pm
Best thing to do with any tern plate tank is put it in the garbage and fabricate a new aluminum one out of 5052.
Date Posted: July-10-2010 at 9:15pm
Tim,
True if the boat had a tern plate tank but if it was judged, and the judge found a aluminum replacement it would be a point deduction. Now in Keegan's case, the aluminum came from the factory so it's cool to refresh the original by just cleaning it up.
BTW, tern plate tanks were just used for maybe 10 years in the 60's. galvanized before that and then the aluminum became popular.
Also of interest, a 73 can be judged under the current ACBS guidelines.
Date Posted: July-12-2010 at 4:41pm
Nothing too exciting in there. I had about a quart of fuel left and dumped it into a metal fire pit I have and it was gone by the afternoon. I took all of the attachments off and sprayed it out with water and put it in the 95 degree sun and let it dry out for 2 days. I dont have an air compressor but I did hook the shop vac up to it for about 10 minutes and let it pull air through it before putting it out in the sun. The sun worked best.
Posted By: MartyMabe
Date Posted: July-12-2010 at 5:12pm
Keegan
No You-tube video of our day out on Oak Hollow Lake Saturday the 10th?
Took Keegan out for a ride in the 'ole 66 Skylark! All he sent me was 1 pic.
66 Skylark
http://www.correctcraftfan.com/diaries/details.asp?ID=5041" rel="nofollow - 93 SN
If you're not living in NC, you're just camping out!
Posted By: kapla
Date Posted: July-12-2010 at 5:17pm
Originally posted by MartyMabe MartyMabe wrote:
Keegan
<a href="">1992 ski nautique
Date Posted: July-12-2010 at 6:09pm
I cant figure out how to get the high def video onto you tube. My Sony camera records in true 1080 and saves to a .MTS file and I cant figure it out. Any techies out there have any suggestions. We did a sustained 36 mph and I did catch it all on video.
Thanks Marty! I needed some time on the water!
Date Posted: July-14-2010 at 2:15am
Keegan
Just took me a day to figure it out! Thanks Marty! Listed on off topic as Mabe's '66 Skylark
