Question about auto bilge function
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=18532
Printed Date: November-18-2024 at 7:38pm
Topic: Question about auto bilge function
Posted By: skyway2k
Subject: Question about auto bilge function
Date Posted: July-13-2010 at 3:02am
After doing a search of the forum, I believe that I have the pump with a microprocessor in it but I'm not sure. It's a 1991 SN, but I don't see a float anywhere near the pump.
The problem is that when I turn on the auto bilge switch, the pump runs and runs and runs and pumps the bilge almost compeltely dry but it will keep running until I turn it off. I'm afraid to leave it on auto for fear of burning up the motor.
Any ideas if something is stuck or dirty making it "feel" resistance and thinking it is pumping water?
Thanks for your help.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=5240&sort=&pagenum=1 - '91 Ski Nautique
Posted By: horkn
Date Posted: July-13-2010 at 4:01am
If it is one with the microprocessor like mine, it won't have any float switch.
Take the pump out of the clips that hold it to the hull, and see if anything is in there.
If gunk is trapped, it may sense resistance and continue to run.
------------- 78 martinique- refloored, reinforced, stringers re glassed, re engineered interior
Posted By: ttgoddard
Date Posted: July-14-2010 at 12:15pm
Great question as my 1990 SN is doing the same thing, will start but not stop.
So in essence it stops when it doesn't feel any resistance against the vanes from being submerged in water?
I did pop mine out of the strainer to look and the strainer had some dirt around the edges. I will get in there clean it out and look at the motor unit itself to make sure it is clean, maybe blast the output shaft with some WD40 to clean it up if I can see and get to it.
I did read that they are designed to not burn out from continued dry use, but just don't like the idea of it running and running and draining the battery at the same time.
I will let you know how I make out.
Thanks.
------------- 1990 Ski Nautique
351 PCM
Posted By: C-Bass
Date Posted: July-14-2010 at 2:08pm
I don't have one of these, but I suspect that the microprocessor is looking at the electrical load drawn on the pump, not necessarily a physical pressure/resistance on the vanes. So my guess is you have something making the pump hard to spin and it's drawing more load. Cleaning it out, as you have suggested, will probably help.
------------- Craig 67 SN 73 SN http://www.correctcraftfan.com/diaries/details.asp?ID=6103" rel="nofollow - 99 Sport 85SN
Posted By: skyway2k
Date Posted: July-14-2010 at 8:22pm
Thanks for your replies! I'll be back in Indiana on Labor Day weekend and will give cleaning it out real well a shot.
Posted By: LAKESIDE
Date Posted: July-27-2010 at 1:25am
Have a 93 SN and mine does the same thing. Wish we could find out what the problem is. Would be great not to have to worry with the manual switch. If any one figures this out please post. Maybe the auto switches are bad?
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=5150&sort=&pagenum=1.com" rel="nofollow - 93 Ski Nautique SUCK MY WAKE
Posted By: skyway2k
Date Posted: July-27-2010 at 1:37am
Not to get off topic, but Lakeside, I see in your profile that you replaced your fuel sender unit. What prompted that? My fuel gage jumps all over the place. It somewhat indicates an approximate fuel level but it continuously bounces between 1/4 and 1/8 of tank either direction randomly. It's not too bad when it's full but 3/4 of a tank or under it goes nuts. I checked the ground wiring and connections on top of the fuel tank and even replaced the connectors but no luck. I didn't have a volt meter with me at the time so I don't have any more info.
Posted By: LAKESIDE
Date Posted: July-27-2010 at 1:46am
Skyway, When i bought my boat my gas gauge was not working at all. So i just replaced it with a aftermarket one. Works great now. Maybe yours is on the way out. Sounds like when your tank gets low the gauge isn't making contact. To replace it you will have to unbolt the tank and slide forward a little to get old one out and to reinstall new one.
Posted By: gun-driver
Date Posted: July-27-2010 at 7:19pm
Dave,
Was the float of your sending unit cork by any chance??
Posted By: LAKESIDE
Date Posted: July-27-2010 at 7:46pm
The original one was. But the replacement was not.
