82 ski tique overheating, Raw water pump good tho?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=18676
Printed Date: November-18-2024 at 6:46pm
Topic: 82 ski tique overheating, Raw water pump good tho?
Posted By: jayc
Subject: 82 ski tique overheating, Raw water pump good tho?
Date Posted: July-21-2010 at 8:22pm
Got a problem with the 82 ski tique I recently purchased. I found when testing it for the first time the other day it had no thermostat and would barely register on the temp gauge.
Ordered one and fitted today and now it overheats so someone must have removed it to solve a problem.
On removing the themostat housing when it had overheated I could see the thermostat was open and indeed on testing the stat in hot water it opens and closes fine.
Now I've pulled the raw water pump hose and there is a very good supply of water from this. The manifolds stay lovely and cool when the engine is overheating so I don't think this is a water supply issue.
I pulled the engine waterpump thinking maybe this was the issue but I can't see any problems with it. Bearings seem good and impellor has corrosion but not loads. Any way I can tell if this is a marine pump or not? I'm thinking maybe an automotive one and because it's a reverse rotation engine it's not pumping enough water?
Anyone else got a suggestion?
------------- 1982 Nautique 2001 - 351W Dual Fuel
1982 Ski Tique - 351W Dual fuel
1996 Maxum 210ss -350 EFI Dual Fuel
Date Posted: July-21-2010 at 9:41pm
Jay,
Does the circ pump look R&R'd? Does it have spiral or straight radial blades on the impeller? The straight radial is the dual rotation pump. Yes, less water flow but still rotating in ether direction will do the job. If someone put a automotive with the spiral blades and it's the wrong rotation then yes, it could cause a problem.
What temp T stat did you put in. It should be the 140 F.
Is this a salt water boat? I'm wondering about corrosion and blockage?
Posted By: jayc
Date Posted: July-21-2010 at 9:47pm
The water pump looks original. Its paint finish and overal condition match the rest of the engine which is untouched.
The blades are straight radial.
Stat is, oh wait my bad....... a 180 stat!
Yep that'll be why it's running up around 180-200 degrees.
What a wally I am!
Date Posted: July-21-2010 at 10:14pm
What a wally I am!
Jay,
You're fine, I'm just going to have to send Roger over by you and beat you silly!! BTW, how close are you to him?
Posted By: jayc
Date Posted: July-22-2010 at 5:32am
Where's Roger then? I'm in Essex which is over on the east coast.
You know I spent a couple of hours pulling the whole cooling system last night for nothing!
Posted By: kapla
Date Posted: July-23-2010 at 6:46pm
If i´m not wrong Roger lives somewhere close to london?
Posted By: jayc
Date Posted: July-23-2010 at 6:50pm
Yeah we all live close to London and often have tea with the queen
Anyhow new stat fitted this eve and all good. Now if i had ordered the right one in the first place I would have saved myself 3 hours work!
Still I cleaned out the stat housing, water pump and raw water pump and gave them all a like of paint. Now to paint the rest of the engine to match.
