Navigation light shorted, Is there a easy fix
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=18993
Printed Date: November-18-2024 at 7:37pm
Topic: Navigation light shorted, Is there a easy fix
Posted By: pmccook1
Subject: Navigation light shorted, Is there a easy fix
Date Posted: August-11-2010 at 12:58am
When I turn the navigation lights on the temp guage pegs out past 200.
Dang near caused me heart failure especially after I had just spent a wad of cash on a new pump.
I can turn the anchor light switch on and the rear light comes on and works fine , doesn't mess with the other gauges.
Turn the nav lights on , lights all work, but it pegs the temp gauge.
Where do I start or is there a easy fix for it. a fuse or something.
pmccook1
Current boat:1993 Ski Nautique " Purple "
Have owned : 76' ski nautique, 93' Sport Nautique, 83 Stars and stripes, 47' Chris Craft Continental
Posted By: Donald80SN
Date Posted: August-11-2010 at 1:01am
Check all grounds for clean connections and clean all electrical connections under the dash.
Posted By: Bri892001
Date Posted: August-11-2010 at 3:11am
Is it definitely shorted, or does it just put a big drag on your electrics when it comes on? Does it come on?
Does pressing your horn or turning on your blower affect your gauge at all?
I have some similar issues on my 93 also. I've heard that running a new ground to the dash can help. I removed my dash pod last weekend and cleaned a bunch of connections with this spray contact cleaner stuff. It helped a little. I couldn't find anything that looked like thee ground to the dash though.
If your light isn't coming on, maybe it really is a short. You could unscrew the light from the boat, take it apart and see if anything is touching in there. The light itself is somewhat prone to failure, I just replaced mine. I had tried a bulb but it didn't last long as water was getting inside I think.
Posted By: pmccook1
Date Posted: August-11-2010 at 4:56am
All the lights work when you hit the switch. The horn hasn't worked since I bought the boat, have'nt tried to fix it either.
Just the navigation light switch makes it go crazy.   The anchor / parking light that just runs the rear light does fine also.
pmccook1
Date Posted: August-11-2010 at 9:16am
I'd like to mention that this problem is not a "short" The term is commonly misused for any electrical problem typically when the person using it knows very little about electrics! A short is a near zero resistance in a circuit and if fused/breakered properly will blow/trip that fuse or breaker. This problem is the opposite with a high resistance. This high resistance, in this case, is from corroded connections and the use of undersized wire up to the dash. Trying to get current through with these problems is causing a voltage drop and in turn causing the high reading on the gauge.
I suggest getting larger wire up to the dash. Not just the ground but the "hot" feed as well.
All connections under the dash as well as the harness plug(s) at the engine must be cleaned. Not with a spray "contact cleaner" as it's not designed to clean connections but rather actual contacts in switches and relays. Connections must be disconnected cleaned with something abrasive like a Scotch Bright pad and then I suggest reassembling with dielectric grease.
Look for any bad "Sta-con" crimped on connections. Loose and or corroded inside the crimped area.
As a example, I was having the problem with my Tique when I got it. Just cleaning up the wiring I picked up 2.7 volts!! That's a lot considering the nominal 12 volt system! I also have bad .250 Sta-con quick connects at all my fuse holders. Cheap non marine that on some had actually broken at the female quick connect end.
The harness plug was another bad one. Green inside!!!
Posted By: kapla
Date Posted: August-11-2010 at 6:44pm
mine does exactly the same...still in the to do´s list...
<a href="">1992 ski nautique
Posted By: pmccook1
Date Posted: August-11-2010 at 9:00pm
thanks brainerd,
   That was what I was gonna do ,,,, crawl my big Ass under there and start cleaning.
Any perticular brand of Dio grease I need to keep on hand ?
pmccook1
Date Posted: August-11-2010 at 11:07pm
Phil,
No particular brand, just what's at the auto supply. Not Autozone!!!
Report back!
BTW it's "Pete" it's cool!!
Date Posted: August-11-2010 at 11:51pm
Actually, if you have a '93, you remove the four little thumb screws and the dash will come up, your connections are under there. If you crawl underneath, you'll see some wires, but you can't get at the connections without undoing the screws and moving the dash.
Luckily, the screws are really easy to get at, although it's helpful to have a stubby flathead screw driver to get at some of them. Just don't pull too hard on your wires as you lift it. What's a little tricky is keeping the dash propped up in such a way that you can work on the connections comfortably.
I'd definitely start by unscrewing your bow light, taking it apart (two little screws hold it on and another two hold it together, and seeing what's going on inside. Especially if the nav light is your only issue.
Let us know how it turns out.
Posted By: ErikM
Date Posted: August-13-2010 at 3:10am
IIRC you can lift the dash up,unplug both wire bundles and then remove the tubes from the back of the speedos and then you can work on it however you like. Along with adding another ground, I replaced the diode with a bigger one because it was burning through the wire cover.
Posted By: pmccook1
Date Posted: August-18-2010 at 10:43pm
Cleaning the front light out and cleaning the wire ends fixed the problem.
pmccook1
Posted By: harddock
Date Posted: August-20-2010 at 12:15am
Thanks for posting your results. Much too often we have people ask for help and never find out if anything suggested was tried or worked. The are many helpful folks out here only to happy to help. It's nice to know you have the problem solved.
http://www.correctcraftfan.com/diaries/details.asp?ID=4487" rel="nofollow - 1998 Ski Nautique
Posted By: Cahill
Date Posted: August-18-2012 at 7:42am
I am having the same issue with my 93. All my gauges go crazy when I turn on the navigation lights or push the horn These are the only two items that cause this reaction. so I'm thinking maybe a ground issue? I looked under dash everything seems to be in tack. Where does the main ground come in at to the dash and what does it hook up to first? Any help on this would be much appreciated. Thanks
Date Posted: August-18-2012 at 9:34am
Davis,
I'd say the problem comes up almost weekly. You may want to use the search again but the solution is pretty simple. The - and + wiring feeding the dash is marginal so running larger is the answer. Also every connection from the engine forward needs to be cleaned up and then assembled using dielectric grease. Eliminating all the daisy chaining by the use of terminal strips under the dash is another big improvement. Many have done it with fantastic results.
