94 dash pod
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=19398
Printed Date: November-20-2024 at 12:45pm
Topic: 94 dash pod
Posted By: blink
Subject: 94 dash pod
Date Posted: September-09-2010 at 11:23pm
has an one had a problem with the sun distorting their dash pod. I was thinking of trying to bend it back down and flush with a heat gun. any thoughts thanks
------------- BTW looks like I lost my 82-2001 to sanity
Posted By: Chopper
Date Posted: September-10-2010 at 1:23am
The pods appear to be a PE or PVC type plastic, so it should work. I would suggest that you remove the pod to do it. I would probably also try to peel back the vinyl first. If you just apply heat to the outside, I think you will damage the vinyl cover if you were not extremely careful.
Got any pics.?
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=1540&sort=&pagenum=2&yrstart=1996&yrend=2000 - 98 Ski
Posted By: blink
Date Posted: September-16-2010 at 12:13am
thanks for the advice chopper I will peel back the vinyl ,and be extra careful not to get it to hot. It is pretty distorted . I will have to put that project off for a little while still trying to get the 81 to ldle .thanks again
