new motor will not idle
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=19472
Printed Date: November-20-2024 at 12:37pm
Topic: new motor will not idle
Posted By: blink
Subject: new motor will not idle
Date Posted: September-16-2010 at 12:35am
bought a long block off of CME,great guys to work with,but as luck would have it (bad) sent the wrong rotation engine ,found that out a little to late had everything put together ready to install all the way up to the distributor didn't slide into place so tore it all down and sent it back. got the right rotation one back installed it took her down to the river and by the way i did rebuild the carb, boat was sitting for 4 years and the carb was pretty bad . couldn't get it to idle below 1500r's timing was on.and as i tried to get it lower it would just die off. plus it was hard start again. It seems to be sucking to much air from somewhere . and i did put all new gaskets on . any ideas thanks
------------- BTW looks like I lost my 82-2001 to sanity
Posted By: SNobsessed
Date Posted: September-16-2010 at 12:45am
Try spraying carb cleaner or WD40 at suspicious spots around carb base & manifold joints. The RPM will change when you hit the leak.
Posted By: blink
Date Posted: September-16-2010 at 1:01am
thank chris i will do that and let you all know what i find
Posted By: gun-driver
Date Posted: September-16-2010 at 12:45pm
Blink
I'm no carb guru but did you try to adjust your idle mixture screws? Also did you pull a vacuum reading that would be a good indicator of a leak.
Which boat got the new power?
Posted By: blink
Date Posted: September-16-2010 at 8:47pm
Hi Paul It was the 81. I did try to mess with the idle mixture screws holley web sight said to start with 1 1/2 some told me a 1/4 turn out by then the carb backfired so i figured out i was done probably blew out the power valve bought a new one give it another shot some time this week. Got a pig roast this weekend down at the docks , come on down if your free bring nan and peanut
Date Posted: September-16-2010 at 9:27pm
Got a wedding on Saturday but free Sunday, how would that work for you guy's.
Posted By: blink
Date Posted: September-16-2010 at 10:57pm
pig roast is on saturday but shell and i will be down all weekend . Sunday will be great we will save you and nan a dock slip let me know call 412-965-0166
Date Posted: September-16-2010 at 11:17pm
