Replacement speedo
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=19483
Printed Date: November-20-2024 at 12:33pm
Topic: Replacement speedo
Posted By: strappatc
Subject: Replacement speedo
Date Posted: September-16-2010 at 11:20pm
Hello all...
I have loved following the forum, and have not posted before, but the advice has been outstanding in looking at areas I need to make adjustments or have someone make adjustments for me.....
I have a 1993 Sport Nautique, with about 375 hours on it, runs outstanding, interior is mint, and always carefully maintained. Used 3-4 months each summer on Squam Lake in NH, faithfully covered, and carefully maintained each fall and spring.
2 years ago I started getting lots of water coming OUT OF the right speedo, leaking across the dash across the front, and dripping down on my feet while driving. The solution was to pull the tube from the back of the speedo and plug it with a screw..... Seems to work, drips every so little, but made the speedo useless....
This year the left speedo died. It does not suck any water into the cockpit, but does not register at all......
I am looking for solutions on repairs.   I am really not experienced, but going to pull the boat this weekend, so will have it on dry land to play.   I can get a new airguide from n3boatworks.com don't know if that will be the solution?
Any advise would be greatly appreciated. I have tried to search old topics, and not seen these exact questions!
Any help would be great.
Find something you like doing, and find someone who will pay you to do it!
Ed
Posted By: tullfooter
Date Posted: September-17-2010 at 10:04am
There is a thread on a group buy discount on new GPS speedos. Looks like it perfect timing for you.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=19315&title=group-buy - GPS Speedos buy
Play hard, life's not a trial run.
'85 BFN
'90 BFN
White Lake, Michigan
Posted By: MartyMabe
Date Posted: September-17-2010 at 11:09am
Ed, it also looks like you need a Performance Engineered For   personalized plaque for the right side of that dash!
mtmabe@northstate.net
Marty
66 Skylark
http://www.correctcraftfan.com/diaries/details.asp?ID=5041" rel="nofollow - 93 SN
If you're not living in NC, you're just camping out!
Date Posted: September-17-2010 at 11:15am
The speedo that is puking water either has its inlet line disconnected, or it has a broken diaphragm. Pull the dash and see whats going on behind it... if the leak is coming from the speedo itself, a replacement from N3 or White Lake is your easiest solution. The one that is simply not registering is more likely suffering from a plugged line... I would take a quick look at the pitot at the transom to see if you can probe any sediment from the pickup. If not, try switching lines at the dash, as you know the other line is definitely working!
Posted By: 63 Skier
Date Posted: September-17-2010 at 11:55am
Ed, welcome to another NH guy! If by any chance you don't get the boat pulled this weekend let me know, I'd love to hit you up for a ride in a '93 Sport to check it out. I've been looking at possibly buying one and an up close look would be great.
Maybe use Tim's advice to get one speedo working, then buy a gps for the 2nd speedo?
Posted By: Fl Inboards
Date Posted: September-17-2010 at 12:58pm
Ed,
Welcome aboard!
You could be the 10th to get this group sale off the ground!
Or continue with inaccurate obsolete componetry for the sake of Originality, Besides I dont think that White lake nor N3 is going to give you any breaks on parts. Karen might be a prefered source for older Correct Craft parts and they support this site!
Good luck and again glad to have you on board!
Jody Seal
Florida Inboards inc.
Panama City, florida.
