ballast tanks
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=19705
Printed Date: November-20-2024 at 10:22am
Topic: ballast tanks
Posted By: 98ski-AIR!
Subject: ballast tanks
Date Posted: October-09-2010 at 4:28pm
Is it important to fill ballast tanks with antifreeze? If so how do you do it and how much do you need?
1998 Sport Air Nautique
Thanks
------------- Pat
Posted By: akabulla
Date Posted: October-09-2010 at 8:12pm
I have only had fat sacs but I can't imagine you would need to put antifreeze in the ballast tanks. After they are empty if there is any water left and it freezes it would just cause you to have a small ice cube in the tank. Maybe blow out the lines with some compressed air like you would a hot shower line.
The issue with freezing water is it will expand when frozen and if there isn't any room for it to expand it will expand in whatever it is in. Like in an engine you get a cracked block because the freezing water didn't have any where to go so it went out throught the block. Like putting a coke in the freezer - BOOM!
Posted By: Okie Boarder
Date Posted: October-10-2010 at 3:53pm
I've heard of people putting a little antifreeze in there, but doesn't seem necessary. I've also heard about a capful of bleach, mainly with bags, to prevent mold / mildew.
