93 OE Temp,Fuel Gauge,Heater Core
Category: Buy and Sell
Forum Name: Boat Parts Wanted
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=19714
Printed Date: November-18-2024 at 4:28pm
Topic: 93 OE Temp,Fuel Gauge,Heater Core
Posted By: MartyMabe
Subject: 93 OE Temp,Fuel Gauge,Heater Core
Date Posted: October-11-2010 at 11:07pm
OK, fellows. The 'parts finder' guy needs help. Looking for an OE white-faced VDO temp gauge and fuel gauge. The temp gauge in there now is a replacemnet Faria. The fuel gauge is erratic at times. Cleaned everything, checked grounds, still bounces around. Do all gauges do this?
Also, while on the lake this weekend, noticed a fair amount of water at my feet near the kickboard(cockpit side). The boat has a heater. So maybe a hole in one of the heater hoses or a busted heater core, my thoughts. Hole would have to be in the right place for it to run on decking between the carpet though. Also the bilge hose runs on that side, but it's ok.
Any thoughts? Contacts on getting gauges, keep me in mind.
------------- 66 Skylark http://www.correctcraftfan.com/diaries/details.asp?ID=5041" rel="nofollow - 93 SN If you're not living in NC, you're just camping out!
Posted By: Gary S
Date Posted: October-12-2010 at 12:02am
Marty,being an old guy and an old boat guy,I cannot remember what your gauge looks like. Check http://www.egauges.com/VD2_main.asp - here ,I have bought from them before and was happy with their service.If all else fails,call vdo tech support at 800-265-1818 maybe they can help,they were helpful to me.
Posted By: storm34
Date Posted: October-12-2010 at 12:03am
Marty, Timely post!
I have some of the same issues going on with out 96. Erratic fuel gauge, its not terrible but does bounce around a bit. Mine is also a faria, so if you find one, send me the info!
As for the water by the feet...here is what I've been battling. I have water at the drivers feet, along the black trim down the driver side and under the back seat. I haven't checked the bilge pump, but I think it's coming from the back as I can see it seep into the bilge under the gas tank when I back just the transom into the water on the trailer. Not sure what this could be?
Posted By: kapla
Date Posted: October-13-2010 at 6:29pm
my fuel gauge is erratic also! but mainly its tank sender related..part of the resistance is missing so less than 1/2 tank I have no more readings...
As for Marty´s leak on the feet..might want to check the speedos tubing..or guages..if broken they leak also to the feet..
A while ago (last year) while trying to solve my non working oil pressure guage I found a site that had VDO gauges in similar models to the ones our boats have..might want to do a search..
I ended up fixing mine..the coil wire was loose and after welding it back again it started woarking...
Posted By: kapla
Date Posted: October-13-2010 at 6:47pm
can´t find it..Tim or Pete might remember it as it was one of the first thing i got to solve with the help of the site...
Date Posted: October-13-2010 at 6:52pm
MartyMabe wrote:
Any thoughts? Contacts on getting gauges, keep me in mind. |
Marty, your best bet at finding something close is to look at Summit. They carry a line of white faced VDO gauges whose bezels are pretty similar to your originals. The exact gauges are NLA... I pieced together a set for my '90, but it took me several years to find good used and NOS. I still have to swap around a bunch of faces, bodies and bezels. Easily the hardest parts Ive ever had to find.
Chris, your '96 gauges are different- I believe theyre Teleflex. I would imagine theyre easier to find than the VDO's.
As far as the water goes, do some investigating. Like was mentioned, the 2 most likely causes are the heater core and speedos. Also check to see if your bilge pump hose is solid.
Posted By: Hollywood
Date Posted: October-13-2010 at 7:07pm
It's probably the heater core, those things do rot out.
Posted By: kapla
Date Posted: October-13-2010 at 8:08pm
here I found the site
http://www.egauges.com/VD2_main.asp - egauges
Posted By: Gary S
Date Posted: October-13-2010 at 9:41pm
Sebastian you didn't read my post
Date Posted: October-16-2010 at 5:09pm
Dang HW --Kevin-- why would you have to wish that the heater core would be bad on me
That's what it is guys. Oh, well, I asked the wife if the boat needed the Heater in it.
She said if it came with the Heater, then put it back on there!
So I guess, I'll be looking for a Heater
Date Posted: October-17-2010 at 6:05pm
I just sat there and looked at that HC-1 HeaterCraft Heater. It is all pop-riveted together.
I went off and left it sitting for about 3 hours. I looked on the internet for prices and thought, It's no good so I'll tear into it. Drilled a few of the pop-rivets out, opened it up, and to my amazement, it looks like an older Ford heater core!It has 3 small pinholes in it when I pressure tested it.
Turned it over and it's stamped 1/15/92--Automotive Heater Core.
So, come Monday, I guess I'll pull the old book out on the Heater Cores, look at the measuremnts and hopefully match it up!
If I get lucky ,I'll post the number for future failures.
Although I did find Ford replacements for 96 and up on the net.Those are like with 3-speed fans, mine is just 1-speed.Sorry about the mess on the shop floor.
Date Posted: October-17-2010 at 8:29pm
Marty, I think you'll find that the information has already been shared... the heatercraft cores should correspond to some sort of Ford- either a van or a Crown Vic if I remember correctly.
Date Posted: October-17-2010 at 11:34pm
Yeap, done did all the digging and my heater is quite different from the replacement cores. It must be first generation or something, hence the HC-1 unit #. The 'newer' cores are taller than my box would accomodate. You have to get the new box or shell with their core ,then you have to get a fan.
