looking for distributor clips
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=19733
Printed Date: November-15-2024 at 6:57pm
Topic: looking for distributor clips
Posted By: WOFTAM
Subject: looking for distributor clips
Date Posted: October-14-2010 at 1:57pm
While inspecting the 1981 SN I bought on July, I noticed that one of the clips that holds the cap on the distributor is gone. The boat ran fine but it looks as if the clip was broken off at the base of the distributor. The PO zip tied it but it bugs me. I would like to buy. A junk distributor remove the clip and toss it. I would then take the clip and remount it to mine which was updated to electronic by the same PO. Any ideas as to where I could find a junk distributor?   Thanks
Just because you can does not mean you should.
Posted By: eric lavine
Date Posted: October-14-2010 at 6:44pm
post a pic of the good clip, maybe me or someone will have one lying around.
Posted By: 75 Tique
Date Posted: October-14-2010 at 7:40pm
Any independent (i.e. one stall garage) boat mechanics around. They usually have a ton of odds and ends parts sitting around. I got a few clips for the linkages on my carb from one after I proceeded to drop mine into the abyss of my bilge.
Posted By: WOFTAM
Date Posted: October-14-2010 at 11:52pm
Next question is what type of voodoo will ensue if I pull the distributor to take it around? Anything I need to mark beforehand?
Posted By: Gary S
Date Posted: October-15-2010 at 12:09am
If you have to ask,wouldn't it be easier for you to post a picture,someone here will have one.
Posted By: YooperSully
Date Posted: October-15-2010 at 12:37am
If they are the solid aluminum ones, with the bend in the middle, Look up the part # in Mallory's catalog and then go to your local parts store and they should be able to order it for you. That's what I did earlier this spring for mine. I wanna say they were eight bucks for the two.
http://www.amazon.com/Mallory-670-Marine-Cap-Clip/dp/B000BYEL9Q - ????
87' 2001
Posted By: WOFTAM
Date Posted: November-01-2010 at 10:53pm
This is what I have to replace. It took me awhile to get a pic...
Anyone have a set to sell?
Anyone know where I can get a set?
Posted By: RV7driver
Date Posted: November-02-2010 at 12:13am
I think I have an old distributor, but it is in the UP and I am in Chicago. I don't know when I will be back up there, could be Xmas, but I will grab the distributor when I am there and you are welcome to it. I changed to a new Mallory with electronic ignition and it runs much smoother and starts easier.
Pete DeCraene
87 Ski Nautique
Pete DeCraene
N526PD
