rudder 88 barefoot
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=20070
Printed Date: November-20-2024 at 8:38am
Topic: rudder 88 barefoot
Posted By: amhfire
Subject: rudder 88 barefoot
Date Posted: November-28-2010 at 6:44pm
i have an 88 barefoot and the rudder has some play when you grab it and move it back and forth. I pulled the entire assembly out and the packing looks bad but there is still place between the rudder and the through hull sleeve. is this normal or do i buy a new rudder and assembly. thanks, also any idea what size packing for the rudder and drive shaft for the boat thansk jared boston
Date Posted: November-28-2010 at 6:51pm
Jared,
Just re pack the rudder log. It will tighten it up. The log and rudder stem were never a precision fit.
Posted By: amhfire
Date Posted: November-28-2010 at 7:02pm
thanks a lot i will try that, im still trying to find out the size. 1/4 or 3/16 the old one is shot any ideas. thanks
Posted By: SNobsessed
Date Posted: November-28-2010 at 9:37pm
Use 1/4 & 3/16 drill bits as gage pins to find out how much clearance there is between the gland nut & the shaft. I think both 3/16 & 1/4 were used off & on, so you need to measure to make sure you order the correct size.
