Transmission Mount - Nut Size?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=20267
Printed Date: November-20-2024 at 8:30am
Topic: Transmission Mount - Nut Size?
Posted By: flipflop
Subject: Transmission Mount - Nut Size?
Date Posted: January-02-2011 at 10:05pm
Evening all,
Hope everyone had a good holiday. I need to tighten one of my transmission mount nuts. I don't have any wrenches over an inch. I am looking to buy one, but not exactly sure of the size.
Transmission is a PCM 1.23. I tried to measure it and came up with 1 5/8". It is close quarters back there and couldn't really get an accurate measurement. Would a picture help?
Thanks.
Posted By: eric lavine
Date Posted: January-03-2011 at 9:33am
1 1/16 or 1 1/8
Posted By: flipflop
Date Posted: January-04-2011 at 6:29pm
Need some guidance - more details on why I need a wrench.
A little embaraced that I spent all this time trying to make things better and seems like I made them worse.
Problem
After my alignment and oil change there was a very significant vibration from the prop shaft. So much so that it would stall out when putting it into gear (forward and reverse). It use to just do it in forward and figured my transmission was going, but now it is doing it in reverse too.
Notes
While at the ramp I ran the transmission with the coupler disconnect and it shifted very smoothly. Does this tell me anything?
When doing my alignment, I noticed one of the nuts on my transmission mount was loose. Here is a picture of it (not mine). For alignment adjustments, I could only move the front of the engine.
(Thinking of alignment is after the sturt..) I had to lift my prop shaft slightly more than expected to get it to fit the coupler. My thought is that maybe the transmission mount should be adjusted a little lower to better meet the coupler.
I have read on the following topics from this board to gather information:
1. Prop shaft being bent.
2. Bad strut bearing.
3. Strut alignment.
4. Transmission issues.
5. Worn damper plate.
Hope you don't mind my trival questions.
Thanks.
Posted By: storm34
Date Posted: January-04-2011 at 6:43pm
I would say so, but I'm not well as versed on this issue as others. Did you have the alignment correct when you took it apart?
If so, I would think the next place to look would be the shaft log and the strut to make sure everything is in line. Pop the rubber hose of the shaft log and make sure the shaft isn't rubbing or off center. This could cause friction, and I guess if it's REALLY bad it could stall out the boat?
Are you sure you don't have a bent shaft or strut?
ps what year/model boat are you working on?
Posted By: flipflop
Date Posted: January-04-2011 at 7:02pm
Sorry, thought my profile had the info. I guess I need to get a picutre so they can update it.
1989 Ski Nautique - 2001
351w 1100 hours - pcm 1.23
Any tricks for getting the hose off? I tried, but didn't see another way besides cutting it off.
Prop shaft has some resistance when turning while disengaged from the coupler, but can be turned by a few fingers.
For the prop shaft or strut, they are not visually bent. While checking my alignment any gap I had was stationary. Doesn't mean there not bent though.
Transmission does have a dirty neutral that seems to be getting worse.
Posted By: storm34
Date Posted: January-04-2011 at 7:16pm
I don't have any tricks to remove the hose. But I would wonder if the drive shaft is riding on the shaft log since it seems pretty difficult to move. Otherwise, I couldn't think of any other issues with alignment or anything that would stall the boat? Thats about where I'd call the professionals. (Eric)
Date Posted: January-04-2011 at 7:18pm
If your gap between the couplers didnt move around when you spun the shaft, then it shouldn't be bent between the strut and coupler. Its possible that its bent aft of the coupler, but I would properly align it first. Your first attempt at alignment sounds like you made it worse instead of better.
Before starting, you need to grasp the concept of what youre trying to do... you want your powertrain (engine/transmission) to be perfectly aligned (position and angle) with the strut. The shaft must also clear through the shaft log without hitting. With a properly installed strut (assuming its not bent) then the shaft should be essentially centered in the log. You then will need to move the powertrain to match the position of the shaft where it spins freely. It sounds like you forced the shaft away from this position in order to bring it closer to where the engine/trans is currently sitting.
You need to break your rear mounts free so you can move the engine where it needs to go. Before struggling too long, pull the shaft log hose off and see how well the shaft is centered in it when it rotates cleanly. If its hitting the edge or way off center, then your shaft is probably bent. If its centered just fine, then move the engine to match that position and dial in the alignment to within .003" per Eric's instructions.
The fact that the engine is stalling when you put it in gear suggest that youre binding due to severe misalignment. You should be able to spin the prop with one finger with everything bolted together if its properly aligned.
Date Posted: January-05-2011 at 8:29am
keep in mind, if you remove the shaft from the trans it will drop some when pulled away, the important part is it must be in the center of the log, then you pull the shaft up to the coupling and install 1 bolt finger tight and then start your alignment check with the feeler blades.
That nut you are talking about is a locknut and probably is 1 5/8's but its impossible to get a wrench in there. personally I use an air chisel with a flat blunt punch to get it to tighten, for the up and down on that type of mount you would turn the threaded center bolt because the transmission trunion (2 bolt mount0 is threaded
Date Posted: January-05-2011 at 8:35am
how bad is the drag on the transmission? typically if you do have bad drag in forward and you put the transmission into reverse, at times it will stall the engine because in theory with warped forward plates the transmission will act as if it is locking up. its an 89 i see and in the early years of that tranmsission they did problems with the forward clutch drums cracking at the base allowing leakage and slipping
Posted By: flipflop
Date Posted: January-05-2011 at 1:12pm
I will check the log position and go from there.
Eric, thanks for the reply. So it's just a matter of time before a rebuild and the extra drag from misalignment is just making it worse.
Why does the transmission shift so smoothly into gear when the coupling is dettached? No stress?
Date Posted: January-06-2011 at 10:33am
actually the firmer the shift the better shape the transmission is in, smooth lazy shifts are a sign of internal leakage
Posted By: BuffaloBFN
Date Posted: January-06-2011 at 12:11pm
After reading this, I think I'd recheck the alignment. It works when the coupler is diconnected? So something must be binding behind the coupler?
Posted By: flipflop
Date Posted: January-06-2011 at 12:29pm
Thanks, it doesn't cost anything to investigate and it will be a good learning experience.
Just working my way around the boat, learning the basics.
Date Posted: January-06-2011 at 2:26pm
The biggie basic on alignment is to start from the strut. With the coupler disco'd, get the shaft centered in the strut and move the engine to where the shaft wants to be. Right now it looks like your engine is all the way to starboard in the back. Normally you'll have 3/4"-1" of the post showing all the way around but not necessarily equal.
