PCM 1:1 transmission question
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=20628
Printed Date: November-20-2024 at 6:42am
Topic: PCM 1:1 transmission question
Subject: PCM 1:1 transmission question
Date Posted: February-12-2011 at 7:32pm
Hopefully someone here can tell me what Im looking at. My sister bought this PCM 1:1 transmission to drop into her Mustang. It had been sitting on someone's shelf for a few years, but it is brand new. I am not sure what I am looking at on the output shaft end. Obviously it is missing the output coupler. Do I simply buy one and bolt it on somehow? Or am I missing more than that? What do I need to do to be able to drop it in place of the outgoing Velvet Drive? I will probably need a little help making sure it is indexed properly as well.
A phone call to Eric is probably in order, but a picture is worth a thousand words.
Posted By: boat dr
Date Posted: February-12-2011 at 8:20pm
Tim, you are going to need a few more parts , appears your missing the rear bearing carrier too.New parts will be pricey, used should work just fine. A call to Eric is in order....Nothing is that simple...
------------- boat dr
Posted By: eric lavine
Date Posted: February-13-2011 at 10:21am
well now, you could build a v-drive boat......sitting in someones garage for a reason.
you have a transmission that accepts a Walters v-drive.....but, you'll need a output shaft and coupling which are available for 2 easy payments of 29.95 and 14.95 shipping. I think the case we'll be fine with the 6 bolt holes if not i can come up with a case also.
call me monday
Date Posted: February-13-2011 at 11:41am
Thanks Eric- Ill call you Mon!
