Velvet Drive Transmission Question.
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=20704
Printed Date: November-20-2024 at 6:20am
Topic: Velvet Drive Transmission Question.
Posted By: BlizagaXx
Subject: Velvet Drive Transmission Question.
Date Posted: February-20-2011 at 10:32pm
Hey guys. I've got a 1979 Ski Tique 16' with a Ford commander 302 in it. The transmission gave out, it is a Velvet Drive model 1017-002. I found a guy selling one for pretty cheap, but it is out of a 1982 Nautique with a 351. I know the 302/351 blocks mate the same way transmission wise, but this Nautique has a Velvet Drive 1017-003 in it. So the real question is...
What is the difference between a Velvet Drive 1017-002 and a 1017-003, and will the 003 work in my tique as a replacement.
Posted By: eric lavine
Date Posted: February-21-2011 at 9:30am
yes, its actually an upgrade because the 03 uses 2 reverse plates insted of 1
what exactly happened, maybe your damper snapped?
Date Posted: February-21-2011 at 9:59am
Do check the damper plate as Eric mentioned but also keep in mind there may be a reason the trans you want to buy is so cheap!! BTW, what do you consider cheap? Depending on what you find with the damper, you may also want to consider sending the old trans to Eric for a rebuild.
Welcome to CCfan. Is your boat in the diaries? If not, get the info into Keith so he can post it. We love pictures!!!
EDIT: Just in case you don't know what the damper is, it's the spring loaded coupling between the engine flywheel and the trans. They do go out. Make sure you put a new one in with ether trans.
Date Posted: February-21-2011 at 10:32am
200.00 tops for a used trans......unless it was a new take-off. but like Pete said, transmission "cores" are cores and they are sitting around for a reason, A transmission that sits for extended periods will give you grief
Posted By: Keeganino
Date Posted: February-21-2011 at 4:43pm
Since the title is up there I have a VD(go ahead guys) question too. Noticed I have a small amount of ATF on my coupler. Does not seem to be enough to drip into the bilge but its there where it does not belong. Checked the dipstick and the level looks good. Likely culprits?
------------- "working on these old boats may not be cost effective but as it shows its what it brings into your life that matters" -Roger
Date Posted: February-21-2011 at 5:42pm
Keegan,
Almost every type of seal leaks to some extent and it's the leakage that lubricates the sealing surface. I wouldn't worry about it until it gets excessive to the point where it's spraying all over the inside of the dog house.
Date Posted: February-21-2011 at 6:12pm
Thanks Pete. I sent you a PM before posting this on another topic. Thought I had your email already but its not in my contacts.
Date Posted: February-21-2011 at 7:28pm
Keeganino wrote:
Thanks Pete. I sent you a PM before posting this on another topic. Thought I had your email already but its not in my contacts. |
Keegan,
I'll take a look in the morning when I get to work.
My email at work is: pbrainard@shalestamping.com You may find the old address but I still get them as well.
Date Posted: February-21-2011 at 9:23pm
Well I talked with Jasper transmission, and they said the 03 is a reversed transmission. Meaning the engine ran the opposite way.. I don't know how true this is.
This is what happened to my transmission. I was out on the lake, backed into the marina, and that was it. It still moves in reverse, not forward. There was a ton (I assume all) of trans fluid on the bilge. I was towed in, and here I am now. The fluid looked good, not burnt. I added more fluid when I got home and it just went to the bottom as well.
So does the 1982 Nautique with a 351 spin in a different direction than the 1979 Ski Tique with a 302? Or are they the same?
Date Posted: February-21-2011 at 10:04pm
So does the 1982 Nautique with a 351 spin in a different direction than the 1979 Ski Tique with a 302? Or are they the same? |
Well, Jasper trans must not know very much about trans's!! They all can run both directions. All it takes is a pump index on the front end to match the engine rotation. I highly recommend not talking to them again!!!
Eric I'm sure will be by in the morning but he's the guy to talk to. It's his business rebuilding marine transmisions!!! I looked for his website for a phone # but it looks like his site is down. It's called Fantastic Finish Marine in Medina Ohio.
Date Posted: February-21-2011 at 10:49pm
what Jasbo's is talking about for instance, is the difference between lets say a 10-17-004 and a 10-17-003 is the pump is indexed for a particular rotation, one for a right one for a left, thus the different model numbers are for reference. The transmissions are identical and you can use either one or visa versa if the pump is indexed correctly.
i would love to know what jazzbo's get for a trans.
It sounds to me like the front seal gave out either due to age or its pushed out and cocked from the pump having excessive clearance and wear.
