Replacing Exhaust Hose...
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=20747
Printed Date: November-20-2024 at 6:34am
Topic: Replacing Exhaust Hose...
Posted By: kman
Subject: Replacing Exhaust Hose...
Date Posted: February-25-2011 at 8:50pm
I'm about to replace the leaking exhaust hose from my copper pipes to the transom exits flaps. Should this be fairly easy or is there something I should be aware of? Will the new ones seal right away with the hose clamps? Am I supposed to seal the metal thru-hull flange against the outside of the transom with some 5200 or just screw it in tight?   Thanks for the tips... Kirk
Kirk
1976 Southwind 20
Eagle Mountain Lake Fort Worth
Posted By: anthonylizardi
Date Posted: February-25-2011 at 10:15pm
Kirk,
I didn't had to remove my flange but one of them was leaking so I sealed it with 4200. The hoses are tought, PITA. To get it out just cut the old one with a hack saw or dremell. I pretty much had to put mine at both ends and jump on top until they went in into the bilge. That was it for me. Soapy water helped. I used two hose clamps on each end.
Date Posted: February-26-2011 at 10:12am
Originally posted by anthonylizardi anthonylizardi wrote:
Kirk,
A reminder that this is a USCG reg for below the waterline.
Date Posted: February-26-2011 at 11:43am
Kirk,
     I had no idea this was a requirement, but I did put two clamps per end.
