stand or not to stand
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=20785
Printed Date: November-20-2024 at 6:46am
Topic: stand or not to stand
Posted By: lakedog55
Subject: stand or not to stand
Date Posted: March-01-2011 at 3:44pm
Hi,
I have had two good sources say not to put the boat on stands. I am inclined not to, but would like another reason to put it on stands. When I lift up on the boat I can see the bottom moving. I have also noticed some hairline cracks , that I did not before around the chines.
Looking Thanks Mike 352-361-8068
------------- Lakedog55
Posted By: Ranger
Date Posted: March-01-2011 at 4:16pm
If you pull the stringers while it is setting on a trailer, the bunks will deform the bottom of the hull. The only way that I know that you can prevent this from happening is to set it on stands.
Jeff
Date Posted: March-01-2011 at 4:24pm
Leave it on the trailer and add some stands at the chines for extra support.
Posted By: storm34
Date Posted: March-01-2011 at 4:43pm
Take a while and read some of the rebuild threads here. The 'Pumpkin Patch' thread talks about stands and support as I know many others do as well. The search feature is your friend.
Posted By: boat dr
Date Posted: March-01-2011 at 5:07pm
8122pbrainard wrote:
Leave it on the trailer and add some stands at the chines for extra support. |
Gotta agree with Pete, extra support aft.The eye ball works real well for plumb and square,but a bit of time with a tape and a plumb bob will make the job easier......not to mention Correct........
------------- boat dr
Posted By: WakeSlayer
+1
------------- Mike N
1968 Mustang
Date Posted: March-01-2011 at 5:25pm
+1 |
+2
In addition to the chine blocks, we blocked the keel as well... this kept the deflection to a minimum while we were inside the boat installing the structure.
Posted By: kapla
Date Posted: March-01-2011 at 6:29pm
wow, you really had a tight space there Tim!!!
Posted By: boat dr
Date Posted: March-01-2011 at 7:17pm
Tim, I just do not think I would have posted that picture. Possibly the most hacked together thing I have ever seen. I can only imagine what the inside looks like if thats what you concider proper support for the outside...........
Posted By: Hollywood
Date Posted: March-01-2011 at 7:22pm
lakedog55 wrote:
Hi,
I have had two good sources say not to put the boat on stands. |
And what was their reasoning for this? What if the boat did not have a trailer, then what would you do?
Date Posted: March-01-2011 at 8:43pm
boat dr wrote:
Possibly the most hacked together thing I have ever seen. I can only imagine what the inside looks like if thats what you concider proper support for the outside........... |
Billy!! What's the problem with a few cement blocks? Some of us do what we can with what's at hand. I've put plenty of boats up on blocks. We've all seen worse "hack jobs"!!
Date Posted: March-01-2011 at 9:06pm
Thanks Guys,
I suspected it needed supports. I cut the first secondary from a pretty decent one and at the aft it was almost 1 1/2 inches high. All be it not perfect yet I trimmed it a little still need to fine tune, but it is much better, I would never had thought the boat to be out that much, I am so thankful I took a moment and asked for your guys help, thanks a million I owe someone a beer when ever we meet
Date Posted: March-01-2011 at 9:21pm
Pics of the stands and helper, Not the most beautiful stands but very efficient
Posted By: Air206
Date Posted: March-01-2011 at 9:39pm
Great Stands and Great helper...............
No matter what anyone says!!!
------------- https://tinyurl.com/y6t5e3bu" rel="nofollow - 04 Air206 http://tinyurl.com/9urzgls" rel="nofollow - 91 Barefoot 78 SkiTiq
Posted By: storm34
Date Posted: March-01-2011 at 10:03pm
Stands look good, but why do you have it lifted so it's not touching the bunks?
Posted By: Keeganino
Date Posted: March-01-2011 at 10:22pm
Yep you want it on the bunks and the stands at the same time. I can 1 up Tim's "hack job". Hey but it worked and I got through it.
------------- "working on these old boats may not be cost effective but as it shows its what it brings into your life that matters" -Roger
Posted By: DrCC
Date Posted: March-01-2011 at 10:49pm
Which is worse, a hack job or a rush job?
Either way you decide to support the boat, it's a good idea to have it all supported before yanking out the stringers. Don't forget to support the forward keel.
Date Posted: March-01-2011 at 11:00pm
yeah about the height, I pretty level side to side but a little more out front to back, made the jacks for the back first and raised the front with the trailer jack and that is where it ended up, nothing a floor jack underneath the prop guard can't handle. By the way I do want to level off the old stringers for front to back? That is what I did the gunnels seem to be rising but the stringers are level.
Thanks Mike
Posted By: DrCC
Date Posted: March-01-2011 at 11:14pm
It doesn't really matter front to back, just as long as your hull is not twisted.
Date Posted: March-02-2011 at 10:17am
The floor or stringers are not level front to back? It seems a whole lot easier if the boat is pretty level. On the secondarys with it level I can make one mark and then take it to the table saw for final height cut. but help me if I am wrong I thought their should be some sort of plane the stringers are running on. After the first one is in I could level from side to side, but without the boat being level(front to back) I would have to level in the exact spots on each stringer.
Date Posted: March-02-2011 at 11:34am
lakedog55 wrote:
The floor or stringers are not level front to back? It seems a whole lot easier if the boat is pretty level. On the secondarys with it level I can make one mark and then take it to the table saw for final height cut. but help me if I am wrong I thought their should be some sort of plane the stringers are running on. After the first one is in I could level from side to side, but without the boat being level(front to back) I would have to level in the exact spots on each stringer. |
Mike,
You can't use a level unless the boat was adjusted first leveling it off to the tops of the old stringers before removal. It's best to measure off known reference points such as the floor at the hull sides.
Posted By: storm34
Date Posted: March-02-2011 at 11:46am
Since you still have the old primaries in, I would drop it down onto the trailer and re adjust your stands. Then I would level the boat front to back and side to side taking measurements off of the primary stringers.
Date Posted: March-02-2011 at 12:07pm
Whether you bring the trailer up to the boat or bring the stands down doesnt really matter- but I would want as many bracing points as possible.
Level is all relative... the stringers/floor, hull and deck will not necessarily run parallel. Leveling off the stringers/floor would make the most sense, I would think.
Date Posted: March-02-2011 at 5:05pm
Yeah, me too, and the boat is level at this point it least it was yesterday, that was without any beer so a may have to re adjust. I was going to do just that, I was going to set my stringer height about a 1/4 inch higher than where the old wood was that causes all the problems. maybe an 1/8. Thanks
Posted By: WOFTAM
Date Posted: March-05-2011 at 1:10pm
boat dr wrote:
Tim, I just do not think I would have posted that picture. Possibly the most hacked together thing I have ever seen. I can only imagine what the inside looks like if thats what you concider proper support for the outside........... |
As a new member, I would like to suggest CONSIDERING the usefulness of such comments.
I use this site as a resource of technical information as well as support and encouragement. Reading comments in a public forum like this makes me reconsider dragging my boat to a CC reunion.
There is no doubt in my mind that it would not be selected "best in show", but I sure as heck do not want spend my time and money traveling to a reunion only to be subject to such scrutiny in a public fashion.
I propose that we remember the purpose of this forum which is listed at the top of the page:
Ask questions or be helpful guidance to fellow Correct Craft owners; buy and sell original parts; or discuss anything Correct Craft related.
I am now off my soapbox.
------------- Just because you can does not mean you should.
Posted By: Air206
Date Posted: March-05-2011 at 1:26pm
Everyone gets crabby sometime...... and sometimes the public filter is not set "ON".............
It happens less on this site than on other Watersports sites.
We are a CCFan family.... not everyone is perfect, (the Boat Dr is one of the first to admit that) but we are a family none the less......
Posted By: boat dr
Date Posted: March-05-2011 at 3:23pm
WOFTAM, read into the post what you want. There is a proper way to support a boat while internal stringers or other work is performed. I did not agree then nor now. Futhermore if you would have posted the pic ,I would have called you on it too.
I have made several CCFan events over the past years,and I have learned a lot from other members.Most here are family, not some screen name on a PC.We swap parts,info, phone numbers and how the kids are doing in school.
Both how to do it Correct and how to "half fast", can be seen at any event and on a lot of threads. Which catagory do you fall into?I hope you are a Do It Correct Guy, if so welcome aboard, and hope to see you at an event with your CC.........Billy
Posted By: eric lavine
Date Posted: March-06-2011 at 10:03am
I think even some swap wives
Posted By: boat dr
Date Posted: March-06-2011 at 1:09pm
That is a TMI statement Eric, but if I may ask, what did you swap her for?
Posted By: Air206
Date Posted: March-06-2011 at 1:39pm
Ha, Ha...... you've been around the resin fumes too long if you don't know why they swap wives............
Obviously, to find one that will let them have the most Correct Crafts! Why else?
Posted By: 81nautique
Date Posted: March-06-2011 at 4:38pm
2 guys sitting at a bar
First one says "I got a dog for my wife"
Second guy says " Good Trade!"
------------- You can’t change the wind but you can adjust your sails
Posted By: p/allen
Date Posted: March-06-2011 at 8:30pm
| Very funny. I laughed very hard on that one. Then I shared it with Wendy. She thought at first it was funny . Then aftyer a bit , not so much.
------------- Pat
http://i175.photobucket.com/albums/w146/72ccfan/100_5977-1.jpg - My 72 Skier
Rock River
Dixon,ILL.
Posted By: boat dr
Date Posted: March-06-2011 at 9:06pm
Obviously, to find one that will let them have the most Correct Crafts! Why else? |
I must have hit the lotto with Karen .....
1949 CC Dart
1955 CC Commuter
1956 CC Collegian
1964 CC American Skier
All those boats and a 4 dog women = THE PERFECT WIFE.
Posted By: jbear
Date Posted: March-06-2011 at 11:46pm
boat nurse..very close to perfect...but perfect to me is mrs. jbear...can drive for any kind of sking, back the trailer or load the boat.
I had to laugh out loud too Pat...but I did not show the joke to Patti.
Now...what was this thread about?
john
Posted By: jeffro28
Date Posted: March-06-2011 at 11:47pm
i would like to trade my wife for a boat please ill even give some money to boot
Posted By: connorssons
Date Posted: March-07-2011 at 12:18am
jeffro28 wrote:
i would like to trade my wife for a boat please ill even give some money to boot | Pics of wifey first? then well talk
Posted By: Air206
Date Posted: March-07-2011 at 12:40am
Be careful Jeff.
Just like boats, they always look better in the pictures than up close!!
Posted By: OverMyHead
Date Posted: March-07-2011 at 12:42am
Take my wife.....please.
------------- For thousands of years men have felt the irresistible urge to go to sea, and many of them died. Things got better after they invented boats. 1987 Ski Nautique
Posted By: jeffro28
Date Posted: March-07-2011 at 8:41pm
