Acid Wash???
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=20800
Printed Date: November-20-2024 at 6:27am
Topic: Acid Wash???
Posted By: Tag962
Subject: Acid Wash???
Date Posted: March-02-2011 at 12:53pm
What works best to clean algae and stains off of the Fiberglass?
------------- Greg
Posted By: 63CCSN
Date Posted: March-02-2011 at 12:56pm
I use a product called Slimey Grimey. It's a poweder you mix with water and spray on the hull. Then you rise it off. Just follow the directions on the product.
Posted By: DrCC
Date Posted: March-02-2011 at 12:57pm
Mel Gibson as "Josh Acid" on SNL said:
"Acid is like a woman, a really good one will eat right through your pants."
Posted By: storm34
Date Posted: March-02-2011 at 1:17pm
Posted By: mdvalant
Date Posted: March-02-2011 at 2:23pm
storm34 wrote:
Or SnoBol
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=5009 - '90 Ski (sold)
http://www.correctcraftfan.com/diaries/details.asp?ID=5479 - '00 Sport
Mississippi River - Bellevue, IA
Posted By: Randy_in_Ohio
Date Posted: March-02-2011 at 3:40pm
When I purchased my boat it had been neglected for a couple years and had a lot of scum dried on it under the water line. I tried the Acid boat cleaner and the toilet bowl cleaner. None of it was working very well, so I tried some Purple Power and it worked great! I just sprayed it on full strength let it sit for a little bit and used a stiff brush to scrub it then rinsed off with the hose.
That Acid stuff is nasty, and it will cause your trailer to rust like crazy.
Give the PP a try, it only costs about $5 a gallon at Wallyworld or Autozone.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=1602&yrstart=1991&yrend=1995" rel="nofollow - 1993 Sport Nautique
Posted By: Tag962
Date Posted: March-02-2011 at 3:45pm
Thanks for the info! Very helpful!
------------- Greg
Posted By: wingwrench
Date Posted: March-02-2011 at 6:04pm
We had a marina in NE Tn for quite a few years. We found the best way to clean hulls was with a steam cleaner to get the algae off and then snowbol toilet bowl cleaner to cut the lime deposit. The key was to hit it with the steam cleaner as soon as it came out of the water, if the algae dried it turned to concrete. We used muriatic acid until we found the snowbol. The acid worked but was brutal on the trailers. A good coat of paste wax after, helped to prolong the next cleaning. The boats up there would slime up in 10 days during the hot summer months.
Jack
