Time for Carb Rebuild?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=2093
Printed Date: November-23-2024 at 12:13am
Topic: Time for Carb Rebuild?
Posted By: Guests
Subject: Time for Carb Rebuild?
Date Posted: July-18-2005 at 11:53am
We've had our 86 Ski Nautique (351 PCM with Holley 4160) about two weeks now and it's been running great until the other day. Going fine at 1/2 to full throttle,
but when I throttled back it started to run rough, then quit. started back up fine, then the same problem. I looked in the carb and gas was dripping from one of the primary side venturis. I'm guessing that the needle and seat need replacing, I've ordered a kit from skidim. Also, it doesn't happen 100% of the time like I would have expected. Does anyone have any thoughts or advice on this?
P.S. This is a really great site!
Posted By: RobG
Date Posted: July-26-2005 at 11:50pm
Rebuilt the carb using the skidim kit. The worst part of it was cleaning off the old gasket material, but the bottom line is: problem solved!
Posted By: GottaSki
Date Posted: July-27-2005 at 9:33am
Just doing the carb may be fruitless...
Change your filters and IF the fuel pump is original I would change it too, else the symtoms can repeat.
River Rat to Mole
