1980 Valve Cover Gasket
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=21165
Printed Date: November-20-2024 at 4:20am
Topic: 1980 Valve Cover Gasket
Posted By: Wacko
Subject: 1980 Valve Cover Gasket
Date Posted: April-04-2011 at 2:26pm
Hey All,
Probably a silly question but, is there any difference between a valve cover gasket for a 1980 351 Commander marine engine and a regular 1980 351 auto engine? Can you just pick them up at the local auto parts store?
Thanks
Posted By: Fl Inboards
Date Posted: April-04-2011 at 3:19pm
Yes you can pick them up at any auto parts store however buy premium / performance brand and not a house brand.
Date Posted: April-04-2011 at 3:24pm
Jody is definitely right.
If youre not in a huge rush, the PCM gaskets (available at SkiDIM, etc) are pretty nice- they are cork and have metal washers around the bolt holes, so they prevent you from compressing the gasket too much when you torque the valve covers down.
Posted By: Hollywood
Date Posted: April-04-2011 at 3:43pm
Do this because the tilt of the engine along with the stamped steel covers are just looking for a place to leak.
Posted By: Wacko
Date Posted: April-04-2011 at 8:24pm
Thanks guys. I appreciate the info.
Posted By: horkn
Date Posted: April-04-2011 at 9:53pm
I've never had an issue with either all rubber or all cork ones.
Then again, I know not to torque the heck out of them.
I'm pretty certain you can get the nice ones like the PCM ones from jegs or summit at least.
Posted By: 81nautique
Date Posted: April-04-2011 at 10:19pm
The issue is that with the steel insert you actually CAN torque them down properly so the bolts don't back off with vibration and not crush the stamped valve cover while doing so. I also put a dab of locktite on my valve cover bolts, they will never leak or back off.
Posted By: Matt R.
Date Posted: April-05-2011 at 12:25am
can you get the valve cover over the rockers without removing the manifold
Matt R.
Posted By: horkn
Date Posted: April-05-2011 at 2:44am
easily. Well at least the PCM's you can. I don't think the other options were any different either.
My aftermarket taller trick flow VC's are taller than the stock ones and they still can barely be taken off or put on without touching the exhaust manifolds.
Posted By: malibud
Date Posted: April-06-2011 at 1:13am
how do you get the the bolts w/o taking the manifolds off ? or is the 80 that much different than an 85 351 ?
Posted By: horkn
Date Posted: April-06-2011 at 2:48am
Use a wobbler attachment if needed.
