lesser expensive steering cable option
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=21461
Printed Date: November-20-2024 at 2:24am
Topic: lesser expensive steering cable option
Posted By: Swatkinz
Subject: lesser expensive steering cable option
Date Posted: April-25-2011 at 12:54pm
My steering is getting stiff. I haven't loosened it from the rudder yet to see if its stiff w/o the rudder, but I do believe it's probably time to swap out the steering cable.
Cable for my boat can only be purchased thru a CC dealer for around $300. Some other CC model steering cables are significantly less expensive ($190 or less) and can be purchased from other sources. I'm told that the cable for my boat is a special length and other cable options won't work mainly b/c of the rudder's tiller arm. Is replacing the rudder tiller arm with a different tiller arm an option? If that could be done, could a lesser expensive cable be used w/o sacrificing performance? The added expenditure of the tiller arm could wash out any savings, but I wonder. If the boat is kept long enough to need another cable, the savings would definitely be significant.
Yes, I realize this isn't original, but will it work the same?
Steve
2011 Sport/Air 200
Excalibur 343
2017 Boatmate Tandem Axle Trailer
Former Malibu owner (07, 09)
Date Posted: April-25-2011 at 1:06pm
No, it will not work the same. Going to a standard cable will reduce your throw significantly (10.5" vs. 8.5"). This is a killer on your turning radius, especially at low speed. In addition to the cable, you would want to swap out the clamp tube, as theyre different lengths. Going to a shorter tiller arm and cable combo might get some of that turning radius back, but my logic says that the shorter moment arm might result in increased steering effort.
My recommendation would be to stick with the original, proprietary cable if you have a 82-90 boat.
Posted By: Swatkinz
Date Posted: April-25-2011 at 1:20pm
thanks Tim. appreciate the input
Steve
2011 Sport/Air 200
Excalibur 343
Date Posted: April-25-2011 at 1:30pm
Gaining 2" of throw with a shorter tiller arm would require a significantly shorter arm. I concure that the steering effort would be significantly greater as well. I'd even worry about the steering gear (helm and cable) being able to handle the extra loading.
Posted By: gun-driver
Date Posted: April-25-2011 at 1:50pm
I just had a problem with my '93 Honda's hood release cable not wanting to pull open. I did not want to go through the hassle of running a new cable through the fender and all that. So I disconnected the cable at the hood mechanism and got some clear tubing that would slip over the cable, and then clamped it tight with a clamp. Then I poured some penetrating oil and tranny fluid in the tube, pressurized it with my air chuck while my wife worked the latch from in the car. I repeated the process until the fluid made it all the way to the latch.
It slides smooth as silk now, maybe this would work on the steering cable
Posted By: dillon5
Date Posted: April-25-2011 at 11:45pm
Call the folks at Nautique parts in Whiteville, NC. They will have some great advice for you on this, and see my link:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=20274&title=steering-cable-replacement-on-a-95-sn--do-it
95 Nautique 351
Posted By: Scrawford
Date Posted: April-26-2011 at 4:55am
Steve,
I can't comment on your '88 but on my '97 the stroke was the same with the standard vs. the custom. Furthermore, the extra 6" of length with the custom cable was no big deal. Check my other posts for more details.
Eric
97 196 Closed Bow
Posted By: Swatkinz
Date Posted: April-26-2011 at 10:07am
Eric & Dillon,
Thanks for the input. Apparently the 2001 generation boats have a unique steering cable setup. I'm not willing to sacrifice any functionality so I'm going to go with the original, yet more expensive cable and be done with it. Hopefully, the next one will last another 600 hours.
Steve
2011 Sport/Air 200
Excalibur 343
Posted By: derekskier
Date Posted: May-14-2011 at 3:57am
Up until the late 90's CC used a special cable. Everyone else is correct in saying that it has a longer throw. The type of cable used by these nautiques is the Teleflex rack cable. The 8.5" throw cables (most common type) come in even foot increments, ie. 18', 19' etc. The special cable for nautiques comes in half foot increments, ie. 18.5', 19.5' etc. Any marine dealer that sells Teleflex products should at least be able to order you the cable. To my knowledge, the 2001 used the 18.5 foot cable, and the 90's nautiques used the 19.5.
I can confirm that you can substitute the standard cable, however you will lose some rudder actuation, making your turning radius larger. Last summer, the 19.5 cable was out of stock everywhere, including the manufacturer, so I was forced to buy the 19' cable. It works fine, and it does cost about half as much, but you do lose some turning radius.
Date Posted: May-14-2011 at 5:48am
Derekskier,
Actually you are incorrect, at least on '97 ski nautiques. I bought my boat new in 1997 and just replaced the original cable last summer. I compared my stock cable and the generic cable I had just purchased and they were both the exact same stroke. The only difference was the .5' of cable length.
Eric
97 196 Closed Bow
Posted By: sweet77
Date Posted: May-14-2011 at 8:57am
http://www.correctcraftfan.com/diaries/details.asp?ID=5528&sort=&pagenum=1" rel="nofollow - 76 Nautique
"If you do what you always did,You'll get what you always got!"
"An empty wagon makes t
Posted By: sweet77
Date Posted: May-14-2011 at 9:03am
maybe your both right i am learning CC has used some wild and different designs on many different boats. Steve i would just recommend going back with the original. Give the (Boat Nurse) a call r check out correct craft parts.com Yall should go ahead and make plans to come to the SJRR next year also. good luck with the steering issue.
Posted By: Morfoot
Date Posted: May-14-2011 at 11:18am
Steve, once you pull out the old steering cable DON'T toss it out. I'd like to have/see it. Are there special ends that swagged on the end of the cable? Might be able to get me hands on some cable and could possibly make new ones but just need to know what type of ends they have.
Date Posted: May-15-2011 at 11:24pm
Interesting... possibly 97 was the changeover to the standard throw cable. Good to know.
Posted By: humanity
Date Posted: May-26-2011 at 6:48am
Very good , i like it and want to have a try.
http://www.cheap-wow-accounts.com/ - wow accounts
http://www.runescapesafe.com/runescape-items/ - runescape items
http://www.riftgoldstore.com/ - rift plat
