Lift Ring
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=21524
Printed Date: November-20-2024 at 2:33am
Topic: Lift Ring
Posted By: leftseat88
Subject: Lift Ring
Date Posted: April-30-2011 at 3:01am
Hey All,
I changed my first oil yesterday and everything went very easy. Only one almost huge problem, I didn't see that the old O ring was still on the engine block. When I went to put the new filter on I saw something move and it was the old O ring. That would have been a real problem.
Now the next question is that the bow lifting ring needs some work. The 2 small approximately 1 inch screws on either side of the ring are stripped. When I pulled the 2 screws out the lifting ring seems fairly secure but moves about 1/8 inch when turning it clockwise and counter clockwise.
I would like to have this a little more secure as I am planning on using the ring to clip the cables for a barefooot pole.
Any suggestions?
Posted By: liquidforce38
Date Posted: April-30-2011 at 4:46am
I have the same problem with mine, they were just fine for lifting though.
Mitch
Date Posted: April-30-2011 at 9:03am
Originally posted by leftseat88 leftseat88 wrote:
Hey All,
Any suggestions?
A barefoot booms cables goes to the bow eye in the stem and not the lifting ring.
The cable for a extended pylon goes to a strap around the stem and not the lifting ring. You'll end up with more damage than just loose screws going to the lifting ring.
Vertical lift only on lifting rings. The aft lifting ring is the same.
Epoxy fill the holes and drill new pilot holes.
Posted By: Speednut66
Date Posted: May-24-2011 at 2:11pm
I need to replace the bracket at the bottom of the bow lifting ring which has corroded quite badly. Any advice on resecurring it to the hull?
Posted By: Bri892001
Date Posted: May-24-2011 at 2:27pm
Hey All,
This has happened on 3 out of 3 oil changes I've done on my boat. They always tell you working on cars to check for this, but I've done probably hundreds of oil changes on cars and it maybe happened once in all those times.
These 351s like to hold onto their old oil filter gaskets for some reason.
Date Posted: May-24-2011 at 2:48pm
Brent,
You really haven't said much about the condition of your boats stringers. With a boat of it's age and if they haven't been changed, there's bound to be issues. I'm bringing this up because lifting ring anchoring is very important and there can be problems - we've seen it but mostly on the aft ring. Even though it's rare to get water way up to the bow, you still need to be real careful. CC always went with the cheapest thing they could find and you are seeing it. Pictures would be great showing the extent of the corrosion. I'm worried about the fasteners into the stem.
Posted By: Jones
Date Posted: May-24-2011 at 3:21pm
Hey All,
I agree regarding the gasket. It only had to happen to me once and I'll never forget to check it again. Scary
1979 Ski Nautique (sold)
1997 Ski Nautique
1998 Super Sport Nautique
Posted By: Keeganino
Date Posted: May-24-2011 at 7:06pm
You would have to grind out any remaining bits of the old bracket, then fiberglass a new one in.
