heads - Anybody else tempted?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=2154
Printed Date: November-23-2024 at 12:29am
Topic: heads - Anybody else tempted?
Posted By: GottaSki
Subject: heads - Anybody else tempted?
Date Posted: July-27-2005 at 10:51am
Read this
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=156886&prmenbr=361 - http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=156886&prmenbr=361
and this:
http://www.jegs.com/photos/jegskaase.html - http://www.jegs.com/photos/jegskaase.html
Looks like the most revolutionary heads for the Windsor engines, practically makes them a hemi instead of a wedge, uses std intake & exhaust accessories, and doesn't require fly-cut pistons.
Of course a boat can't use the cams they used in testing, but makes one wonder what a smartly built engine could do, especially a 396 stroker that can utilize the cfm available.
cool beans, no?
River Rat to Mole
Posted By: David F
Date Posted: July-27-2005 at 12:16pm
The "new" Clevor engine! Or, the "new" Boss Engine!
Posted By: GottaSki
Date Posted: July-28-2005 at 9:41am
Yeah!
Junkyard rollercam 351 + $2500 = Boss 351!
If one were going for authenticity, a rollercam 302 + 289 rods and Boss 302 pistons and these heads gets one pretty close to a Boss 302. Plus the exhaust options for boat or car is way better than for the Cleveland heads.
Only hitch could be interferrence with the valve covers and the riser manifold; log-style would be no problem.
River Rat to Mole
Posted By: 64 Skier
Date Posted: July-31-2005 at 5:35am
The advertised chamber is 60cc....if your current heads are 54 (can't remember) then you'll lose compression and possibly see very little gains.
------------- 64 Skier
66" HO VTX and 67" HO Triumph
http://www.correctcraftfan.com/diaries/details.asp?ID=1071&sort=&pagenum=3&yrstart=1971&yrend=1975 - 71CC
Posted By: GottaSki
Date Posted: July-31-2005 at 1:18pm
Uhm, well ... there is more to power than compression... like an extra 100 cfm of intake flow.
River Rat to Mole
Posted By: David F
Date Posted: July-31-2005 at 2:03pm
...and you can always mill them down a bit and use a thinner head gasket. And then do not forget to take a bit off the intake manifold.
Oh, with a bit lower compression, I suppose you could advance the timing a bit without worry of pre-ignition which would probably make up for the lower compression.
