trailer raise
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=21571
Printed Date: November-22-2024 at 9:58pm
Topic: trailer raise
Posted By: malibud
Subject: trailer raise
Date Posted: May-03-2011 at 1:40pm
I would like to lift my mastercraft trailer because it sits so low that i often scrape the prop guard it is a double axel can i just change out the metal spacers under the leaf springs will it cause any harm? thanks
Posted By: TX Foilhead
Date Posted: May-03-2011 at 2:47pm
I did mine the hard way, welded on new spring hangers. If you welded the blocks so the couldn't come out I don't see why that wouldn't work though. The only issue you might have is having to back a bit further into the water at the ramp.
Posted By: Air206
Date Posted: May-03-2011 at 3:12pm
Dan:
Search the threads and you will find a lot of options....... I had similar issue and the biggest difference for me was flipping the axle. There are other options too...... if your axles are within the curve of the spring, flipping them will make a huge difference, easy and CHEAP!..... Lets see some pics!
Steve
------------- https://tinyurl.com/y6t5e3bu" rel="nofollow - 04 Air206 http://tinyurl.com/9urzgls" rel="nofollow - 91 Barefoot 78 SkiTiq
Posted By: Air206
Date Posted: May-03-2011 at 3:13pm
BTW - Don, LOVE your Excel! Nice!!
Date Posted: May-03-2011 at 3:25pm
Thanks, I forgot about flipping, I looked into actually flipping the axel since it had a drop and was already below the springs. The trailer mfg said there was some camber built into the spindles so that option was out for mine.
Posted By: outman007
Date Posted: May-04-2011 at 2:55am
The Well Groomed Golfer
Golfing is one of the most popular past times and has been for decades. Although dress is not as important as it was years ago, the savvy golfer knows how to dress and act on the golf course. Even with the lax standards of today, many clubs do require that golfers adhere to a dress code.One common rule for golfers is that they must wear a collared shirt. No grungy t shirts or tank tops on the greens. Jeans are frowned upon and many clubs even require that you wear long pants. Of course, golf shoes are a must at any golf club - some courses even require that you wear a special type of shoe.
http://www.clubsgolfsale.com/taylormader11.php - TaylorMade R11 Driver
