milky transmission oil
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=21866
Printed Date: November-20-2024 at 2:38am
Topic: milky transmission oil
Posted By: cajunnautique
Subject: milky transmission oil
Date Posted: May-28-2011 at 1:52pm
i have an '83 barefoot nautique that i just bought and it is leaking transmission oil into the hull when i let it sit for a couple of days, the transmission oil is also milky from water. can someone please help me with what the problem may be and what it will take to fix it.
Posted By: Keeganino
Date Posted: May-28-2011 at 1:58pm
Really the only way to get water in the transmission is through the oil cooler. Must have a crack in it. Easy to replace.
It seems to be fairly common for them to leak a little oil through the shaft seal but that is a separate issue. You will probably need to change the oil in the trans a few times to get all the water out of the case.
Posted By: wakeboardin2k4
Date Posted: May-28-2011 at 4:43pm
+1
Keegans right on point with his suggestion
"I'm planning to bring my girl that rides on a trailer with me and leave my girl that complains about camping at home"
Date Posted: May-29-2011 at 12:55am
thank yall. i will change the oil cooler and how hard is it to change the seal? do i need to pull the tranny to do that or can i do it with it still in the boat?
Posted By: eric lavine
Date Posted: May-29-2011 at 11:03am
Kee, from experience and knowing the boating community......its more likely the plug was left in and the boat flooded, but again 2 sources of water would be the cooler and flooding the boat
