1200 rpm warning light
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=21869
Printed Date: September-27-2024 at 1:38pm
Topic: 1200 rpm warning light
Posted By: drtybrdy9
Subject: 1200 rpm warning light
Date Posted: May-29-2011 at 12:18am
The warning light that says to not operate boat if the light stays on above 1200 rpm stays on when the engine is over 1200 rpm. What is the most likely issue and are there possible "false positives" that would cause the light to stay on? Please help brand new boat and I want to get this figured out ASAP. Thanks
------------- http://correctcraftfan.com/diaries/details.asp?ID=5402&sort=&pagenum=1 - 05 SAN Limited 210
Posted By: gun-driver
Date Posted: May-29-2011 at 1:41am
Oil pressure sensor or temp sensor.
Check to make sure you can rule out both of those two things are not actually causing the light. Then you can start tracking down the bad sensor.
Posted By: TX Foilhead
Date Posted: May-29-2011 at 1:52am
That's the Vdrive oil pressure sensor light. If it's on the Vdrive isn't seeing oil pressure. Not really a false positive, but if it's low that would cause a lack of pressure. You want to have that checked out because Vdrives aren't cheap.
Posted By: wakeboardin2k4
Date Posted: May-29-2011 at 11:33am
Did you do all your basic fluid checks? Trans, oil, vdrive fluids? Just trying to rule out the basics.
------------- "I'm planning to bring my girl that rides on a trailer with me and leave my girl that complains about camping at home"
Date Posted: May-29-2011 at 9:15pm
The v drive oil was a little low, got that where it needs to be and the light still is on. I am a little confused, is there a v drive and a transmission? I thought the v drive was the transmission. Please let me know if there is anything else I can try and eliminate before having to drop $ with a professional. Everything else looks great, temp, oil levels, the sound, no weird vibrations or anything.
Posted By: eric lavine
Date Posted: May-30-2011 at 10:55am
does the boat have a Walter's or a ski-vee trans? the Walters did or does have a light that will turn off when the prop shaft turns in either direction, what the walters has is a direction charge pump on the back end of it and in neutral the light will illuminate and as soon as the prop shaft starts to turn the pump creates pressure and the sending unit senses this and turns the llight off.
its a newr boat and i dint know whats down in there for a trans, first and foremost you need to check and post what trans you have
Date Posted: May-30-2011 at 11:01am
btw, I have had this problem with the Walter's in the past, does the light stay on all the time or does it eventually go off....this pump on the Walters does not effect operation of the Walter's, it is a lube, cooling pump, and its purpose is just that, it lubes and cools the bearings....I normally put the boat in gear with someone at the helm and crack one of the rubber hoses on the back of the trans to insure oil flow....its not much flow, but the sending unit is pretty sensitive and will fluctuate and creats problems. the biggest thing is if the light goes out, then you know you have oil flow
Date Posted: May-31-2011 at 3:00am
i wasn't able to check what trans is in the boat before i left for home but i am 99% sure that it is a walters. The light stays on the whole time. if you could please clarify one thing for me, is there a v drive and a trans, or are they one in the same? What i added some oil to was the walters and the light still stays on above 1200 rpm. I am probably going back to the lake next weekend and would love to have this behind me so i can start taking some massive face plants!
Date Posted: May-31-2011 at 9:47am
they are completely seperate units, with their own oil sumps, the front transmission will be a PCM 1:1, that is where you get forward and reverse.
The Walter's is merely a gear connection to get the v-drive configuration, no clutches, just a circulatating pump, as I stated earlier to check if you have oil, you need to run the boat in gear and pop one of the rubber hoses on the back of the Walters and see if you have flow. really when everything is correct you only truly are getting about 5lb.s of oil pressure there.
im going on a Walters call this morning on a 35 carver, not that it matters, but, it would appear to me that your sending unit is acting up
Date Posted: May-31-2011 at 1:42pm
Eric,
Thanks for all the help, I have one more question for you when you say "pop one of the rubber hoses on the back of the Walters" are you refering to the stern side of the walters or the bow side?
Posted By: WakeSlayer
Date Posted: May-31-2011 at 4:14pm
When you say you added oil, did you add pink Dexron III? or 20w oil, and confirm where you put it.
------------- Mike N
1968 Mustang
Date Posted: May-31-2011 at 7:37pm
I put SAE 30 motor oil into what i think is the walters. I basically followed the directions http://www.nautique.com/documents/boatmanuals/2005/206_210_216_226.pdf%20 - here on page 8-16. So is there another place i need to check fluids to get this taken care of?
Date Posted: June-01-2011 at 9:59am
I failed to mention that the 2 bigger lines going into the top of the Walter's are raw water for cooling, dont pop those lines, there should be 2 seperate dipsticks, one for the pcm which takes Dex/Merc and one for the Walter's SAE 30W, that dipstick is on the top cover of the Walter's. actually you could pull the sending unit on the Walters and see if oil comes out there.
the boat i was on yesterday is identical to what you have and it appears to me that the owner stepped on his sending unit and broke it off and the oil pumped to the bildge and smoked the V-drive.
you gotta remember, any time you are adding oil it means a leak, oil doesnt just dis-appear or evaporate, so also if your Walters is low, the oil is going somewhere. its hard trying to convey at this point of what you have going on and i really dont mind taking phone calls 877-369-6693
Date Posted: June-14-2011 at 3:07pm
Eric,
First off, thanks for all of the advice. It seems as if this one is beyond my mechanical capabilities. I did take the hose off of the sending unit, put the engine in gear well past 1200 rpms and not a drop of oil came out. I don't know if there is anything else you can think of but I am planning on bringing it in to the dealer sometime soon, unless you have one more ace up your sleeve. Let me know if you can think of anything else. Thanks again
Date Posted: June-15-2011 at 9:57am
i really hate to see you get hammered at the dealer, i feel at this point that it may be a pump problem, a relatively inexpensive repair...out of site out of mind,
do you know anyone that could pull the Walters section? this could turn into a 3k repair if not monitered.you dont know the times with the same scenario that i will buy the trans because it was replaced and i find a pin or something like a 5 dollar part from keeping the transmission from working...not saying its a simple repair but........
Date Posted: June-15-2011 at 1:55pm
from discussions with the dealer, i was under the impression that the oil pump was inside the walters. does that sound correct to you?
Date Posted: June-15-2011 at 2:06pm
drtybrdy9 wrote:
from discussions with the dealer, i was under the impression that the oil pump was inside the walters. does that sound correct to you? |
Yes and the reason Eric asked if you could or know someone who could pull the Walters out. If so, then you could ship it to him. Better than the 3K at the dealer!!! Plus, the dealer will probably "rebuild" the box using Walter's "available only from them super special not made for anyone else in the world" bearings!!!
Date Posted: June-15-2011 at 5:18pm
when i take the rpms past 1200 how long do you think it would take before the pump starts pushing oil? I was above 1200 for at least 20 seconds and nothing, does that seem like it would be long enough?
Date Posted: June-15-2011 at 7:51pm
the dealer called me back, the bearings are shot and there are metal filings in the v-drive. He said that we are looking at $2200 total to get it rebuilt. Does that sound resonable or are we getting screwed?
Date Posted: June-15-2011 at 8:29pm
drtybrdy9 wrote:
the dealer called me back, the bearings are shot and there are metal filings in the v-drive. He said that we are looking at $2200 total to get it rebuilt. Does that sound resonable or are we getting screwed? |
Ah yes, the special Walter's bearings as mentioned!!!
Eric can tell you about how far you need to bend over. Of course, it all depends on how truthful they are too!?
Date Posted: June-16-2011 at 10:11am
lets put it this way, on the same trans with replacing 2 gears and all the bearings im normally at 1200.00 total....so you tell me, someones going on vacation with that extra g-note your giving away.
typically i am usually right under a thousand with bearings u-joints.
you'll feel better after a while, its probably a better rebuild because of the price difference
Date Posted: June-16-2011 at 10:13am
i would bet they pulled it and called Walter's direct, its rare that a dealer rebuilds in house
Date Posted: June-16-2011 at 11:02am
Mason,
Have you used this dealership before? Do they specialize in inboards or even more important V drives? Where are they? I'm also curious if they told you how long the colonoscopy proceedure would take?
Date Posted: June-16-2011 at 12:28pm
8122pbrainard wrote:
I'm also curious if they told you how long the colonoscopy proceedure would take? |
You're going to feel a little discomfort now, sir.
Bwaaa ha ha ha ha ha ha ha ha ha ha
1968 Mustang
Date Posted: June-16-2011 at 1:31pm
We have used the dealership before. They sell new and used inboard boats as well as other boats. Their name is Island City Water Sports located in Cumberland and Clear Lake, WI. In regards to erics question they are sending the walters out to have the rebuild done and there was a couple options. First, they could send ours out and get all the work done and sent back. Second, and they weren't sure if this was possible, they would send ours out and replace it with an already rebuilt Walters, cutting down on the time the boat would be unusable.
Date Posted: June-16-2011 at 2:03pm
Yank it yourself and send it to Eric.
There's no better way to learn about the boat then to take it apart and put it back together again.
Date Posted: June-16-2011 at 4:44pm
I'm guessing its too late to stop the process, but having looked over my Vdrive I think that would be very easy to get out.
Eric, do these things have a life expectancy, or do they just occasionally go out. I hate the light thing on the dash, I'm not sure I would notice right away if mine had a similar issue. It gets your attention at first, but after awhile you don't even notice it. I would rather have one that came on when there were issues.
Date Posted: June-16-2011 at 5:35pm
TX Foilhead wrote:
Eric, do these things have a life expectancy, or do they just occasionally go out. |
Only the Walters!!!! From an engineering standpoint the box is really a poor design that myself and Eric have commented on several times. The last I heard, which was a couple years ago, CC had phased the Walters out in all but one model and the word was that model too wasn't going to have the Walters in it for very long!!!
Depending on your hours, I'd start planning on one day getting it over to Eric. I'm sure he'll have some ideas on the hours.
Date Posted: June-16-2011 at 5:42pm
Spoke with Eric today. The dealer already has taken out the Walters, since he was sending it out to be rebuilt he doesn't really care where it goes. So hopefully today it will be on its way to Eric.
Date Posted: June-16-2011 at 6:16pm
FWIW I have a friend (really, it isn't me) with the Walters in a 99, with a 502 that has somewhere in the neighborhood of 1350-1400 hours on it, never had a fluid change, and is still just fine. This thing has run pigged out with 2k plus of ballast the whole 12 years.
1968 Mustang
Date Posted: June-16-2011 at 6:50pm
I am pretty sure the PO of my boat was a giant POS. We got a great deal on it and even with this added cost we still are below the amount i see most 05 210 go for. So it sucks, but there was a reason we got it for that price.
Date Posted: June-17-2011 at 10:01am
really, the boxes are designed and built like the Space shuttle, but again, how many times do they delay the flights...its hard to put an hour number on the transmissions, alot depends on what happens to them in the boat
Date Posted: June-17-2011 at 10:35am
eric lavine wrote:
really, the boxes are designed and built like the Space shuttle, but again, how many times do they delay the flights... |
Date Posted: June-30-2011 at 6:29pm
Eric,
Thanks for all the help. We are going to pick up the boat tomorrow, it will be ready for the 4th of July weekend. Also, i think we ended up saving somewhere close to $1000 by sending it to you over Walters. Anyone having similar problems Eric is the place to go. I think the marina is even going to save your information for any future customers with transmission or vdrive problems.
Date Posted: July-01-2011 at 9:52am
thanks for the words....enjoy the boat
Date Posted: July-05-2011 at 4:19pm
Everything went well this weekend. The only thing is at higher rpms there are noticeable vibrations. Is that probably because the bums at the marina didn't align everything properly?
Date Posted: July-06-2011 at 9:40am
very possible
Posted By: DonC
Date Posted: July-08-2011 at 3:54pm
drtybrdy9 and Eric - If you don't mind me asking, what parts were replaced in this V-Drive and what was the cost of the repair?
After reading all the Walters bashing I decided to call them to find out about general repair costs, and get a reference on Eric. To the best of their knowledge, they have haven't sold Eric any parts in at least 10 years, so I have to wonder if he is using new or used parts? Walters tracks each parts order with the V-Drive serial number, so you can call them (201-656-5654) with the serial number of your V-Drive and they'll be able to tell you what parts were ordered.
I also asked about 8122pbraind's comment questioning "special bearings" inside Walter V-Drive. Walters suggested that I don't take their word for it, but that I should contact Timken Bearing company to verify that the performance codes are NOT stamped on the bearings. Apparently the performance codes identify the bearings tolerance on outside diameter, inside diameter, width and the type of honing of the races. They mentioned that bearing supply houses usually only stock general production bearings, not ones made with closer tolerances. If anyone doesn't think that bearing tolerances don't affect function or longevity, they should google "ABEC-7 precision bearings". Here's the best part: Walters gave me the Timken number of one of their bearings along with a price and I checked a bearing price online at Motion Industries.
Guess what, Walter's price is cheaper so what's the beef???
Posted By: Keeganino
Date Posted: July-08-2011 at 4:23pm
Holy hell this guy again! You are kind of like herpes. You go away for a while then come back, but were never wanted in the first place.
------------- "working on these old boats may not be cost effective but as it shows its what it brings into your life that matters" -Roger
Date Posted: July-08-2011 at 4:26pm
You guys went through this once already. Eric does not buy his parts at Walters, so what would the point of calling them be?
Date Posted: July-08-2011 at 4:50pm
I'm very familiar with ABEC ratings and the tolerance that goes with them. As a reminder, the bearings in a Walters are not there for longevity but rather to handle it's poor design using a "U" joint instead of better boxes that use bevel gearing. The "U" joint speed varies twice with each revolution which in turn sets up some real bad torsional vibrations hence the need for the best ABEC rated bearing.
Here's the set of Timkens I worked on a couple weeks ago.
BTW, you can't go by on line prices. They are list and don't factor in the price muliplier for each customer.
Date Posted: July-09-2011 at 3:58am
I would just like to add that any 9 year old skateboarder knows the difference between ABEC 5 and ABEC 7 bearings. Just because Walters does not stamp the specs into the bearing does not mean that it can not be obtained elsewhere for less. They even make ceramic bearings for skateboards.
Posted By: SplashHL
Date Posted: July-09-2011 at 8:37am
I've learned a lot reading this thread...hope I don't need a tranny anytime soon, but if I do, I'm calling Eric!
------------- Whatever
Date Posted: July-09-2011 at 11:10am
the beef is he was quoted 2200 bucks and thats without seeing it, i did it for 1000.00 with a year warranty and im even thinking of kicking it up to 2 year warranty on all of my work because of confidence, im not going to reveal my parts sources because i dont want to get blacklisted again for not purchasing the special ground bearings, but an old man told me long ago, if you dont talk to her someone else will, i know there is a code of the road in business and I can appreciate that, but there is also profit margins in business, my phone rings everyday because of my ethics, im fair, im honest, ive been at it for 25 years, if i fck up i take care of the problems, ive recently even taken care of other peoples problem because the transmission was rebuilt in December and the warranty expired 90 days later, and it didnt work from the get go,
btw, I did it for free and you know what? 2 days later the marina called me to pick up a transmission and was told your the guy from here on out. thats how I work. I changed my mind if you want to try to blacklist me again me here are my suppliers, transmission marine, marysville marine, hale marine, harbour marine, federal marine.......like i said, if you dont talk to her someone else will...........eventually with a little research and building a trusting customer base, all roads lead to Brunswick lol, im just trying to make a living, im not getting rich but i feel i should treat people like how i want to be treated, thats all
Date Posted: July-09-2011 at 11:21am
frogive me for asking, what were you going to do with the extra 1200 bucks?
Date Posted: July-09-2011 at 11:36am
Walters is a dim lit candle waiting on a breeze, and i was very dis heartened when i got cut-off twice (you'll remember, I was Great lakes Power's service manager for 10 years) and it left a very bad taste in my mouth, i would never bash a company but it was a very unethical business practice when i got cut off. I dont do a ton of Walter's but i do my share and i do them because of trust.
Posted By: Gary S
Date Posted: July-09-2011 at 1:27pm
Keeganino wrote:
You guys went through this once already. Eric does not buy his parts at Walters, so what would the point of calling them be? |
I guess Keegan he picks up the phone and dials the other line or the same number if it "hunts" in phone lingo. Liked your other post too
Date Posted: July-10-2011 at 11:24am
all I can add, is if you want to survive in an economy like the one were in, or even to survive in business, there never ever is a word such as "no"
