PCM engine with cracked heads
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=2203
Printed Date: November-23-2024 at 3:45am
Topic: PCM engine with cracked heads
Posted By: Guests
Subject: PCM engine with cracked heads
Date Posted: August-05-2005 at 6:19pm
I have a 91 Ski Nautique with the 351 ProBoss PCM engine. The heads started cracking several years ago with rust lines appearing above the spark plugs that has progressively gotten worse to the point I now need to replace them. I held off doing anything about it knowing sooner or later they would have to be replaced.
My question is...has anyone else experienced the same problem with the PCM engine and what if anything did the dealer and/or PCM do to address the problem?
I know of an owner of a 91 Ski Nautique where PCM replaced the heads at their expense about 4-5 years ago. Anyone else have anything to share on this problem?
Thanks for your help.
Dave
Posted By: SS 201
Date Posted: August-06-2005 at 7:31am
Almost all the old style did mine included.
Posted By: workky
Date Posted: August-08-2005 at 7:06pm
i have an 84 ski nautique that has cracked heads in the same place as you describe.But im still running them,they squirt out a little water
Posted By: Jim_In_Houston
Date Posted: August-08-2005 at 11:25pm
LMAO. Sorry. I am just surprised people are running engines that squirt water out of the heads.
Posted By: jameski
Date Posted: August-08-2005 at 11:57pm
LOL... I guess if you have a good bilge pump...
current boat
http://www.correctcraftfan.com/diaries/details.asp?ID=1977 - 94 Sport Nautique
previous boat
http://www.correctcraftfan.com/diaries/details.asp?ID=601 - 78 Martinique
Posted By: HOLESHOT
Date Posted: August-09-2005 at 4:30pm
LMAO
IF IT HAS A SPARKPLUG I CAN FIX IT
Posted By: john33617
Date Posted: August-12-2005 at 3:44pm
only RWC engines do it , so must be wild temp swings , my fish nautique is RWC and shows no sign of cracking , same PCM , same year , ski boat leaks bad
Posted By: gary93
Date Posted: August-24-2005 at 1:54pm
I have a 93 SN had the same problem. Gave me a reason to go with the HO heads. PCM told me yes they are famous for it. If it is a famous problem why didn't they fix it. Sorry.....
Posted By: Guests
Date Posted: August-30-2005 at 2:45pm
That's what I was wondering as well! If PCM is "famous" for cracked heads, what is/was causing the heads to crack and what did they do to address the problem? I would think they would have made some form of reparation to owners who experienced the problem.
I know of one owner who took their boat back to Correct Craft to have the heads replaced and PCM did cover the cost of parts, but not the labor. This was on a boat that was approx 5-6 years old at the time. However, when I contacted Correct Craft they said, "we've not heard of PCM engines having cracked heads."
I was just curious if any other owners had received any discounts or replacement coverage from either CC or PCM for this problem??
Thanks for any info,
Dave
Posted By: HOLESHOT
Date Posted: August-31-2005 at 2:55pm
hey my heads did the same thing
after my brother overheated the engine until it
blewup
Posted By: GottaSki
Date Posted: August-31-2005 at 5:23pm
I had suspected that was the primary mechanism...
River Rat to Mole
Posted By: Guests
Date Posted: August-31-2005 at 9:56pm
If the engine had ever overheated I would understand that cracked heads could result. But since I'm the orginal owner and know for a fact that it has NEVER overheated something else must be the cause.
