Misc problems
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=22185
Printed Date: November-19-2024 at 8:32pm
Topic: Misc problems
Posted By: trh250r
Subject: Misc problems
Date Posted: June-20-2011 at 2:18am
When I pulled my boat out of storage this year, we noticed that my water pump pulley wheel was not lined up straight with the other pulley wheel. It appears to be slightly off parallel. Can this be shimmed to alighn it properly or is this a sign of a worn part. The belt needs replaced asap. My speedometers are also not working, where can I get replacement parts? My boat also seems to take on a considerable Amount of water when it sits overnight, I have heard it could be my exhaust packing needs replaced, is this an easy task? Lastly, the engine is very inconsistent when starting cold. Sometimes it fires up right away other times it takes wat seems a lifetime to get started? Where should I start to fix this problem.
BTW, this is a 92 sport
Posted By: Bri892001
Date Posted: June-20-2011 at 1:56pm
1.) Do you mean your circulation pump (same location as a water pump in an automotive application) or your raw water pump (mounts of to the side)?
- If the Raw Water Pump: Do you do your own winterization? Is there a chance someone put it back together wrong? The raw water pump houses the impeller, which is often taken out for maintenance an winterization.
2.)Yup, an off center pump would chew up your belts, these are readily available from skidim and others. You shouldn't have to shim it though, and I don't think you could, something is not right... If the bearings in the pump are toasted, the pump can be rebuilt or replaced.
3.) Speedometers: Did you check that there are no obstructions. There's different ways to clear them, but stuff getting clogged in the pickups is the most common issue.
4.) Taking on water: There is no such thing as exhaust packing. Maybe they thought your exhaust outlet hole? Could be your drive-shaft packing or your rudder packing. There are many posts on this, also refer to the reference section and look for an oweners manual that would cover your boat
5.) Need more info:
-Is it cranking strong?
-Do you give it two good pumps to full throttle and back with the throttle/shift lever before attempting to start?
-Is it more of a problem hot or cold? If more a cold problem, be sure your electric choke is actuating.
Posted By: trh250r
Date Posted: June-20-2011 at 6:41pm
It would be the raw water pump , i just boat the boat last August, I did the winterization but never notcied, and i did not take the impeller out.
Thanks for the correction, it would be the drive shaft packing im talking about, I'm going to tighten the nut to see if this helps.
The engine does crank strong, and yes i pump it 2/3 times if it does not start right off the get go. It just seemed like it was not getting any gas. Had a very strong rollover just wasnt starting up, but it finally did. It was never a problem until now. But im noticing it to be more on the cold start.
Date Posted: June-20-2011 at 10:28pm
Not given,
Get you first name in your profile!! I'm older and hate the new screen name routine!!!    Most here go "old fashion" and do use first names!!
Sheave alignment can be corrected with shims but that's only in one direction. To the negative, it's mods or bending brackets. Don't go by eye - get the straight edge out along with the tape measure out and check. Look for the center line off the straight edge using the tape measure since the thickness of sheaves do vary.
You mention taking on water plus the speedo(s) not working. At leak in the pitot tubing and or the pulsation dampeners would account for both. Are you taking on water while under way or moored?
Posted By: trh250r
Date Posted: June-20-2011 at 11:48pm
Im pretty sure im taking on water both times.
Posted By: SNobsessed
Date Posted: June-21-2011 at 12:37am
TRH - My RWP pulley was also out of alignment. I put a thin washer in a strategic spot to get it to align.    Use a straight edge to figure out which way it needs to be shimmed. Hope this helps.
Posted By: BuffaloBFN
Date Posted: June-21-2011 at 8:58am
Moroso makes pulley shims in different thicknesses.
http://correctcraftfan.com/diaries/details.asp?ID=2331&sort=&pagenum=12&yrstart=1986&yrend=1990" rel="nofollow - 1988 BFN-sold
Posted By: trh250r
Date Posted: June-23-2011 at 12:33pm
thank you for the advice
Posted By: echobravoecho
Date Posted: July-14-2011 at 7:19pm
What's the consensus on this one? I threw a belt last weekend after 10 hours of use on a new belt. I was planning on shimming the raw water pump this weekend to attempt to correct the alignment. I think I need to shim it out a few degrees.
Thanks,
Ed
Date Posted: July-14-2011 at 7:28pm
The raw-water pump looks like it was replaced at some point.
My gut is telling me that something didn't go back together quite right with the bracketry...
My engine is a similar vintage. I'll give it the hairy eyeball and take a couple of close up pics if I can so you can compare.
Date Posted: July-14-2011 at 8:46pm
No "eyeballing"!! Get the straight edge (a carpenters square will work) and use it to dial in the alignment. All 4 faces at the OD of the two sheaves must touch the edge of the straight edge.
BTW Ed,
you never install a new belt without check the alignment!! It's so far out that you should have seen it immediately even pulling out the straight edge!!!
Date Posted: July-14-2011 at 10:15pm
You are correct, sir, I am a hack....
It was way out of alignment when I replaced the impeller and belts this spring. I knew it, and ran it anyway. What I could not determine at the time, nor now, is the appropriate technique to correct said mis-alignment. Pre-made shims, ah, what a revelation. I'm heading to auto zone tonight. To use the vernacular of the south, I was a' fixin' to grind my own, and not looking forward to the task. Or take off the bracket and persuade it into a better position. Neither solution was acceptable at the time.
I regret not the thrown belt, nor lament it's early consumption. It was consumed in the pursuit of family bliss, which this boat has provided my family in spades in the short time we've owned it. My girls spent 6 hours in the water last Sunday, all three got up on the wakeboard/starter skis, and the youngest up on the slalom ski for a few seconds before she bit the dust. 6 hours on 6 gallons of fuel, plus a $3.00 launch fee. That's cheap entertainment at our house. They came home tanned, tired and sore. My job is to keep this sled running until wintertime, when I'll have the time to fix all the sub-component failures.
As has been said before, you guys know way too much about these boats and I, for one, am quite thankful of this fact.
Regards,
Ed
Date Posted: July-14-2011 at 10:50pm
After looking at my own pictures, it's still going to be tricky to get the shim between the body of the pump and the mounting bracket.
Date Posted: July-14-2011 at 10:56pm
Ed.
The story id FANTASTIC about your family!!! Keep then going on the water sports as long as it excludes the tubes!!!
DO, if you have any doubts about anything you do with your boat, consult us.
You may need to bend then bracket or add spacers to get the the sheave back in line.
Posted By: Luchog
Date Posted: July-15-2011 at 2:15am
you could add the shims between the bracket and block.
http://www.correctcraftfan.com/diaries/details.asp?ID=2095" rel="nofollow - 1980 Ski Nautique
Commander 351W
Posted By: eric lavine
Date Posted: July-15-2011 at 9:38am
i really cant remember if the pulley is just a press on, if so that could be pulled a little forward??? i have shimmed the brackets in the past and certainly remember shimming the altenaters also
Date Posted: July-15-2011 at 4:26pm
Auto Zone was a bust last night. They only carry fender shims and starter shims.
Here's my current plan for tomorrow:
1. Pull the pump AND the pump mounting bracket. (this I did not do when I refurbed the pump last April)
2. Beat on the bracket with a big hammer. (BFH)
3. Test fit bracket and pump.
4. Repeat until I break the bracket, or straighten the sheave.
5. Re-install bracket, pump and belt.
Sound good! :)
Date Posted: July-15-2011 at 6:24pm
Time out; hold up! Did you watch Pete's video on the proper use of a BFH? This is crucial.
Otherwise, I'd say your plan is spot on.
Look for a speed shop in your neighborhood for a better selection of shims.
Posted By: Keeganino
Date Posted: July-15-2011 at 8:44pm
My original bracket was aluminum and broken, so I bought a new one from Jodi and it took a little bit of playing around to get the alignment just right. Just used washers.
Posted By: Luchog
Date Posted: July-15-2011 at 9:48pm
Sound good! :)
ever heard of WASHERS?
Commander 351W
Posted By: GlassSeeker
Date Posted: July-16-2011 at 1:54am
looks like a bolt head is hitting the bracket messing up the alignment. Can the pump go together different ways? to move that bolt down like in the photo above
This is the life
Date Posted: July-18-2011 at 5:38pm
I played around with this over the weekend and improved the alignment somewhat.
The problem in this case was the angular misorientation of the pulley. It was about 3 degrees or so out of alignment in the horizonal plane and, after close inspection, a few degrees out of alignment in the vertical plane. In other words, it was messed up. This chewed up the belt and caused an early failure.
I also did a little experiement and found that as the belt is tightened, the mounting bracket flexes out toward the front of the engine and the pump pulley shaft flexes in toward the engine, but not the same amount as the bracket flexes out. Plus the mating surfaces between the pump body and the bracket aren't really flat, so there is a bit of movement there also.
So there was actually two problems to solve, the vertical and horizontal. The first solution was to install tapered shims to correct the horizontal problem. But I couldn't find the correctly sized shims with the correct taper. The shims would have to be tapered 3deg and fit between the mounting bracket and the pump body in order to work.
I used the potential interference between the bolt head and the mounting bracket GlassSeeker noticed and used it to create an angular force to change the horizontal component of the angle. I jammed a screwdriver tip and a washer in the space and tightened it until the pump pulley was nearly parallel with the other pulleys. Tightened it down, then found approximately sized washers to replace the screwdriver.
I also used a washer between the pump and bracket on the bottom mount to kick out the vertical angle a little more.
In the pictures you can see the angle before and later with the belt tightened. It's still not spot on.
After the vertical adjustment.
During the horizontal adjustment.
After the horizontal adjustment, tightened down, but before the extra washers.
BR,
Ed
Date Posted: July-18-2011 at 5:51pm
is the bracket bent? I had a bent bracket(Mercruiser) and it was a big heavy bracket and I have no idea how it could have ever gotten bent but it was and so $100 new bracket fixed mine.
This is the life
Posted By: ttgoddard
Date Posted: July-18-2011 at 6:30pm
Your sure you didn't mount it upside down? Looks it to me, as a result one of the three bolts you remove to replace the impeller may be binding with the bracket pushing it out of alignment. I thought the bulbous part of the pump body was on the outside of the engine. How about the bleed screw on the pump, you look at keeganino's photo and you can see the bleed screw on the outside, yours must be on the inside as you can't see it.
Just my two cents worth.
Tony
1990 Ski Nautique
351 PCM
Date Posted: July-18-2011 at 6:48pm
The location of the set screw is rotation dependent, so it being different on the two boats might be normal. I'd guess by the difference in vintage that the earlier is a Right Hander and the later is a Left.
I do have something of interest, from the Aquaskier.com impeller replacement article. Notice how the pump halves are bolted together and the following pic. The head of the bolts that hold it together are astern. Tyler's bolt heads are towards the bow, allowing them to interfere with the mounting bracket.
Date Posted: July-18-2011 at 7:00pm
Looked into it further and it looks like a lot of them have the bolt heads towards the front. I really thought I had it for a second there.
Date Posted: July-18-2011 at 7:03pm
Good point, the motor rotation would be a factor. My pump on my 90 SN looks like echo.... pump, with the bolts heads on the front closest to the pulley (Sherwood G2). I can look at mine tonight to see where my bleed screw is, but I am pretty sure it is on the back with a clockwise rotation looking at the front of the crank from the drivers seat. I have a nice arrow drawn on mine for rotation and water flow, just so I don't put it back on upside down.
By the way, I agree about not beating the cast bracket, castings seldom bend, they typically crack and break in two.
1990 Ski Nautique
351 PCM
Date Posted: July-18-2011 at 9:01pm
This is interesting, this one is angled like mine only in the other direction. I wonder how long his belt stayed on.
As for the backwards part, I was concerned about that also, not having done it before. When I fired it up the first time water pumped up and out the exhaust, I figured it was on correctly. Also the internal wear marks on the impeller matched, the rotation matched the direction the impeller blades were bent, and the hoses lined right back up so it all looked ok.
Posted By: rnaquin
Date Posted: August-04-2011 at 9:29pm
For what its worth, if the pump is installed upside down,   it will still work and the impeller marking will remain "matched up".   You're not changing the direction the the pump is turning, only rotating top to bottom.
