Very Tight Steering
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=22259
Printed Date: November-20-2024 at 12:20am
Topic: Very Tight Steering
Posted By: D.R.Moore
Subject: Very Tight Steering
Date Posted: June-24-2011 at 2:44pm
I'm looking at buying a 1989 Barefoot Nautique. I tet drove it today and the steering is very, very tight. Does anyone have any ideas of why this might be?
Posted By: Bri892001
Date Posted: June-24-2011 at 3:13pm
The steering cables tend to go/seize up. The best way to fix them is to replace them. If it's only while under way (ie with load against the rudder) sometimes the rudder packing/lube could be to blame.
If it's tight all the time, more likely the cable. They are replaceable though: http://www.nautiqueparts.com/steeringcableallnautiquesfrom1982to1990.aspx - Steering Cable .
I wouldn't consider that alone to be a deal breaker.
Date Posted: June-24-2011 at 3:28pm
Would this be something that I could replace or would I need a dealer to replace it?
Posted By: WakeSlayer
Date Posted: June-24-2011 at 3:46pm
Easy to do yourself, but if this is a boat you are considering buying, get the owner to replace it before you do the deal. You need to drive the boat in proper condition before plunking down a bunch of money. Just my opinion.
Mike N
1968 Mustang
Date Posted: June-24-2011 at 3:49pm
Thanks!!
A lot of guys do it themselves, I've never done one though. I believe your back seat would need tom come out, and it would make it easier if you removed your engine cover. There should be a floor panel between the rear seat and the engine cover that will also come out. Then you can unbolt it from the rudder side and un-fasten from the helm side.
I guess the trick is having some sort of a rope/wire line connected to the old one as you pull it out. Then you have a way to guide the new one back in.
If you check out the thread http://correctcraftfan.com/forum/forum_posts.asp?TID=16014&PN=1&title=another-bfn-rebuild - Another BFm Rebuild you'll see a bunch of pictures of an older Barefoot in various states of diss assembly. Not sure if they go into the cable there or not, but they do just about everything else!!
Posted By: BuffaloBFN
Date Posted: June-24-2011 at 9:25pm
That's a great excuse to pull the back apart and see what there is to see. What you'd be after is to disconnect the tiller arm to see if it's still tight, but what you learn on the way might be priceless.
http://correctcraftfan.com/diaries/details.asp?ID=2331&sort=&pagenum=12&yrstart=1986&yrend=1990" rel="nofollow - 1988 BFN-sold
