Fuel cell
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=22496
Printed Date: November-19-2024 at 10:48pm
Topic: Fuel cell
Posted By: SplashHL
Subject: Fuel cell
Date Posted: July-08-2011 at 12:49am
I'm reading up on the how to section on changing out the fuel filter and see that I need to apply "fuel resitant pipe thread sealer" to the 7/16 plug...any brand name product I should buy and if so from whom? Thanks, justin
------------- Whatever
Date Posted: July-08-2011 at 11:02am
Justin,
I'd just teflon tape it.
Posted By: SplashHL
Date Posted: July-08-2011 at 4:08pm
Thanks! I was thinking that would be ok. Also...which end is up on the new thermostat I just bought? The pointy top looking thing, does that go uo or down? Figured you'd know. justin
Posted By: kapla
Date Posted: July-08-2011 at 5:51pm
usually the point goes up....
Posted By: SplashHL
Date Posted: July-08-2011 at 7:46pm
Posted By: jimsport93
Date Posted: July-08-2011 at 8:02pm
Justin, I was able to find gasoline rated teflon tape at Home Depot.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=2798 - 93 Sport Nautique
Date Posted: July-08-2011 at 8:53pm
jimsport93 wrote:
Justin, I was able to find gasoline rated teflon tape at Home Depot. |
All Teflon tape will be gasoline rated. Teflon is very inert and not harmed by much of anything. Now, what you may have found at HD is gaseous rated tape (natural and propane)? I have now idea what the difference is except is yellow in color and 4 times the cost!!
Peter(123) do you know what the difference is? Do you use it?
Posted By: SplashHL
Date Posted: July-08-2011 at 9:12pm
Date Posted: July-08-2011 at 9:38pm
Pete, Home Depot had regular teflon tape and the gaseous rated (natural gas and propane), but they also had gasoline rated, which is what I purchased.
The gasoline rated tape says it is suitable for gasoline, petroleum oils, propane, butane, naptha, benzene, kerosene and natural gas. It was a little more expensive, but not much. I wanted to be sure.
The bottom of my fuel filter/water seperator has a threaded brass drain plug on the bottom of the bowl. I changed the filter element (pcm type) and cleaned the bowl. Taped and re-inserted the drain plug. No leaks!
