82 nautique oil pan gasket
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=22794
Printed Date: June-26-2024 at 10:17am
Topic: 82 nautique oil pan gasket
Posted By: zeclops
Subject: 82 nautique oil pan gasket
Date Posted: July-25-2011 at 1:10pm
Getting closer to finishing up the rear main seal on a 82 351 And yes thanks for all the response on the rear main seal. I am wondering if I can use a automotive 4 piece oil pan gasket or is something unique about the original marine one.
Thanks,
Stan
------------- stan082
Posted By: eric lavine
Date Posted: July-25-2011 at 2:36pm
get the fel-pro marine 1 pc with steel spacers
Date Posted: July-25-2011 at 2:37pm
hanging upside down is a beeoch, 4 pc means 4 places it can leak....trust me on this one
Date Posted: July-25-2011 at 2:39pm
put a damper in there too
Posted By: zeclops
Date Posted: July-25-2011 at 3:06pm
Thanks for the response. Yea I get dizzy hanging upside down. I've completly removed motor and put on stand so that I can clean and rotate. Saves my back as well. I just saw they had a 1 piece of 4 piece at autozone and was checking if they would work on the marine application. I will track down the felpro you mentioned and use that. Thanks for the damper tip.
Stan
