Need help - 2nd voltage gauge install
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=22809
Printed Date: November-19-2024 at 8:20pm
Topic: Need help - 2nd voltage gauge install
Posted By: jhiestand
Subject: Need help - 2nd voltage gauge install
Date Posted: July-26-2011 at 12:13am
There's been quite a few threads regarding the problem with the dash gauge not receiving adequate power. I put a second, "house" battery in my SAN a few years back and want a 2nd voltage gauge to measure its status. I picked up a cool looking Summit gauge that will look awesome in the side panel of my boat. Here's my problem.
The gauge has 3 leads, a RED, BLACK and PURPLE. Since this gauge isn't switched and I don't want it on all the time I plan on using a relay and wiring it to the keypad power. I think I have that part figured out -- hooking it to the +/- of the power outlet on the side panel seems to energize/de-energize the relay the way I'd like it. The issue tho, is how where do I hook up the RED and BLACK leads? I tried as indicated in the attached diagram hooking to the house battery, no dice. Not only did I get no reading, the leads got really hot really quickly. Not good. Any electrical guru's out there have any advice on what I might be doing wrong?
Date Posted: July-27-2011 at 12:19am
I think I've got it solved. The diagram is okay, but apparently my relay took a beat down the first time I hooked it up incorrectly. After trying the gauge and the relay independently of each other, that was the only piece left. Put a new relay in and so far so good!
