Impeller Wisdom
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=2293
Printed Date: January-16-2025 at 3:00am
Topic: Impeller Wisdom
Posted By: tleed
Subject: Impeller Wisdom
Date Posted: August-21-2005 at 4:07am
Couple days ago I pulled the impeller loose to check it out. I had already ordered a new one, but the old one looked fine, so I put it back together. Problem solved.
Wrong.
For some strange reason, I looked in my manual and realized my pump could have two impellers. Only saw one when my pump was apart, though. Today I pulled the pump apart again and discovered there are indeed two impellers! One was shredded toast, the other looked new. This is a Sherwood pump. So I needed the new impeller anyway, which I promptly installed.
Thomas
1969 Barracuda/318 Chrysler
Posted By: captan1
Date Posted: August-22-2005 at 2:22am
I have a 30' Trojan cabin cruiser also and it has twin 318 Chryslers in it, same deal, I think it's a D55 with two water in's and out's and two impellers ea. I just did mine this year and 3 of the 4 where still all there but one was missing about half of the ribs. It's about a $130 deal for me.
The pump ribs are somewhere in the cooling system
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=452&sort=&pagenum=1&yrstart=1978&yrend=1978 - 1978 Ski Nautique
Posted By: tleed
Date Posted: October-04-2005 at 12:43pm
Check out Overton's for this impeller. Sherwood 9959 for $23.
http://www.overtons.com/modperl/overtons/detail/pdetail2.cgi?r=detail_view&item_num=29118
