82 SN Ignition coil is melting my skin
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=22944
Printed Date: November-19-2024 at 8:35pm
Topic: 82 SN Ignition coil is melting my skin
Posted By: Ralexn
Subject: 82 SN Ignition coil is melting my skin
Date Posted: August-03-2011 at 10:59pm
OK,So I have been through, what feels like, every forum on the planet looking for advice on this issue. I have found some helpful advice but none of the conventional wisdom seems to be doing my problem justice. It is a 1982 Ski Nautique, 351 W engine. Like so many other people we crank her right up and take off for a thrilling hour before we hear the engine start to miss. A couple minutes later engine dies and we look like idiots stranded in the middle of the river. We wait for about 20 minutes then fire her back up for about 20-30 minutes until it happens again. Wash, rinse, repeat until we make it back to the ramp. We know that the coil is not supposed to sear your skin when you touch it so We are thinking this is a wiring issue but have had zero luck finding any helpful diagrams. If you can help I will be much obliged. If you have pictures that would be a huge plus as I am more a visual learner.
Thanks,
Ross
Posted By: Luchog
Date Posted: August-03-2011 at 11:05pm
what coil? what ignition? ballast resistor?
Commander 351W
Posted By: Ralexn
Date Posted: August-03-2011 at 11:15pm
The coil is a Mallory 29216, pretty sure it is a mallory points ignition, don't have the part number on me. ballast resistor is in place and to our knowledge wired correctly.
Date Posted: August-03-2011 at 11:16pm
Ross,
First off, welcome to CCfan.It's always great to get new member's to find the site.
The first question I have is has the 82 been "converted with a "EI" modal in the distributor??
Posted By: Ralexn
Date Posted: August-03-2011 at 11:20pm
thanks for the welcome,
As for the distributor, we are old school points style
Posted By: Gary S
Date Posted: August-03-2011 at 11:44pm
Well that is an oil filled coil.Try mounting it to the cylinder head in a way that it is pointed up,instead of on it's side.Of course if it's already mounted upright,nevermind
Posted By: Ralexn
Date Posted: August-03-2011 at 11:52pm
I appreciate the advice Gary, I should have mentioned in my first post that we did in fact mount it vertically for a wet test today, still had the same results.
Posted By: Luchog
Date Posted: August-04-2011 at 12:23am
is the coil loosing oil? have you tried a different one yet?
Commander 351W
Posted By: Gary S
I wonder if the damage has already been done. I have been running a oil filled one for awhile,but just changed it over last night with a new epoxy one and a new resistor.The old resistor was all cracked and I was worried about the old coil.
Posted By: Ralexn
Date Posted: August-04-2011 at 12:42am
We ran the boat until the coil crapped out, then replaced it with a spare. Ran like new, when we got back to the dock we checked it and it was lava hot. I'm starting to wonder if the ballast resistor has gone bad, I will run a voltage check on it tomorrow. I'm looking for 9 volts in the run position, correct? If the resistor is bad what are the specs for a replacement.
Posted By: Gary S
Date Posted: August-04-2011 at 2:50am
The MSD coils instructions I bought told you what resistor to use
