SN Barefoot Boom advice??
Forum Name: Common Questions
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=23389
Printed Date: November-23-2024 at 4:10am
Topic: SN Barefoot Boom advice??
Posted By: NAUTIQUEjunky
Subject: SN Barefoot Boom advice??
Date Posted: September-05-2011 at 5:03pm
I'm looking to get a barefoot boom for my 86 I'm looking for pros and cons of the BI contour boom vs the straight boom.
1977 MasterCraft Stars&Stripes
1994 Ski Nautique
2000 Super Air Nautique
1986 Ski Nautique 2001
1999 Sport Nautique gt40 current
Posted By: kapla
Date Posted: September-05-2011 at 5:39pm
countour will make circulation around the boat easier as the inner section sits lower to the floor, depending on how is set in the clamp it can be monted more fwd or aft. It also allows you to mount both extended pylon and boom at the same time (at list in non ring and finger pylons).
I have a countour boom, so I canĀ“t give you the insight on the straight one....
<a href="">1992 ski nautique
Date Posted: September-05-2011 at 6:03pm
Don't they still make the height adjuster if I find a deal on a straight boom? Also I'm considering the ring saver mount but I'm afraid its going to stick out front of the pylon to far and my family will bang there shins on it a lot.
1994 Ski Nautique
Posted By: kapla
Date Posted: September-05-2011 at 6:07pm
yes they still offer the height adjuster...
Posted By: DrCC
Date Posted: September-05-2011 at 7:31pm
I have the ECI straight boom.
I like the ECI quick-clamp alot better than the BI or Casad clamps that require a wrench or set-screws.
Posted By: DrCC
Date Posted: September-05-2011 at 7:59pm
Although I have heard stories of guys breaking their ECI clamps.   Probably due to improper adjustment, (over-tightening)
Posted By: Swatkinz
Date Posted: September-06-2011 at 10:06am
I run a straight BI boom on my boat with a height adjuster. I can run an extended pylon with the clamp/adjuster/boom in place. My rig works great and I'm told from others on here that the straight boom is the way to go for the 2001 boats.
I will say that you will probably want the extension on these BI booms as the side spray is intense.
Steve
2011 Sport/Air 200
Excalibur 343
2017 Boatmate Tandem Axle Trailer
Former Malibu owner (07, 09)
Posted By: SN206
Date Posted: September-06-2011 at 3:06pm
BI w/ a mid-extension and maybe a end extension.
Posted By: kapla
Date Posted: September-06-2011 at 3:15pm
how do you fasten the BI end extension to the end of the boom? need to remove the red rubber cover? and fasten the set screw in the extension?
Posted By: Hollywood
Date Posted: September-07-2011 at 2:01pm
Yes, you got the idea kapla. It's only a skinny handle for kids, you don't put a rope on it.
Date Posted: September-10-2011 at 4:42pm
I found a contour boom with extension and a toe harness handle for 300 is this a good deal.I'm still wondering which is the best for my 2001 straight one or contour boom. I want to be able to move in the boat with the boom in place and I got a fly high pole as well now. Any one have a pic to help me decide??
1994 Ski Nautique
Posted By: SN206
Date Posted: September-12-2011 at 1:12am
Is it a BI boom?
Date Posted: September-12-2011 at 12:41pm
Lots of pictures, do a search. Swatkinz had a thread with something like "boom advice" in the title.
Posted By: lison
Date Posted: September-12-2011 at 5:45pm
I've got a BI straight boom for our '84 2001. We don't use a height adjuster but put a boat cushion or two between the boom and gunnel to adjust the height. I recently bought a second extension piece that fits in between the two long pieces). Each extension is about 18". The side spray from the boat really drowns you until you get up to speed and extensions help. The side spray is especially crappy for teaching beginners.
L Ison
1984 CC Ski Nautique 2001
351 PCM Ford
Forest Lake, MN
Crandon, WI
Posted By: Donald80SN
Date Posted: September-12-2011 at 8:09pm
I spoke with Mike S. at Barefoot International and he said always go with the straight boom if you can. I got a good deal on a Single contour Straight Boom. It works fine, but the contour makes it hard to adjust in the height adjuster. Some tell me that it is hard to adjust the straight boom in the height adjuster. They are a great tool for teaching kids. I have one on my 80. The sigle countour really does not give you any more leg room in my opinion. It is still a PITA.
Posted By: GlassSeeker
Date Posted: September-12-2011 at 10:20pm
the nice thing about a contour is that you can flip it over and have a very high boom without using any padding.
the contour booms are made to fit boats with windshields wrapping around extending back past the pylon
the height adjuster works well but it is not easy to change with cables hooked up
straight booms work well too but you can't get them as high
I could use either and I prefer the versatility of the contour boom over a straight boom
This is the life
Date Posted: September-13-2011 at 12:19am
I ended up buying the BI Contour Boom with boom extension(fits between poles) and he gave me a Straightline toe harness handle too,all for $300 I couldn't pass up a deal like that on CL.The Boom looks Brand New, the kind fella who sold it to must have OCD like me
I will post some pics this week with it installed on the 86, looking forward to doing some Footin its been a long time..
1994 Ski Nautique
Date Posted: September-21-2011 at 5:04pm
I really like the universal contour boom i put it on the forward setting to get a better resting point away from the side grab rail. I still use a throw cushion under it for added protection.
http://imageshack.us/photo/my-images/594/20110914120833.jpg/">
http://imageshack.us/photo/my-images/855/20110914120126.jpg/">
http://imageshack.us/photo/my-images/707/20110914120026.jpg/">
1994 Ski Nautique
