repalcing steering cable on "88" 2001 SN
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=23612
Printed Date: November-19-2024 at 1:40pm
Topic: repalcing steering cable on "88" 2001 SN
Posted By: marmon77
Subject: repalcing steering cable on "88" 2001 SN
Date Posted: September-23-2011 at 2:45pm
Would like to get some pointers on replacing the cable on my boat. How to get it centered so as to have the same amount of turns right to left from lock to lock. Thanks
Date Posted: September-23-2011 at 3:00pm
Getting the steering travel centered is a function of where to install the clamp block on the clamp tube. This should not change from cable to cable, assuming youre using the proper Correct Craft cable with the longer throw. You have to swap the clamp tube over from the old cable, so it should be clear where it was installed originally. If not, then just play with that adjustment until you have equal travel.
Getting the steering wheel centered is a little trickier... that is a function of the wheel's position when you insert the cable into the helm. It may take a little trial and error for you to get the wheel straight when traveling straight.
Removal/install is pretty easy... I would recommend taking the old cable out from front to back. Tie a rope to it and feed the new cable in from back to front.
Date Posted: September-23-2011 at 3:03pm
Count the number of turns on the helm so you can then center it. Adjust the tube clamp block at the aft end of the new cable until the rudder is centered.
Posted By: marmon77
Date Posted: September-23-2011 at 4:38pm
So if I buy a cable from somewhere else besides NautiqueParts.com the throw (travel) will be different? It's a teleflex rotary cable
Date Posted: September-23-2011 at 4:53pm
You dont have to buy it from Nautiqueparts.com, but you will need to get it from a dealer or another authorized source for Correct Craft parts. While it may appear to be a normal catalog rotary cable, it is not- Teleflex built this particular one (for the 1982-1990 Ski Nautiques) specifically for Correct Craft. They will not sell it to you directly (I have asked). It has a longer throw than the standard cable (10.5" vs. 8") which results in a much tighter turning radius. The 17.5' length is also oddball, but that is a lesser concern.
Posted By: marmon77
Date Posted: September-23-2011 at 9:43pm
Ok, will try and contact a local dealer.
Posted By: marmon77
Date Posted: September-23-2011 at 10:42pm
Will the 17' cable from ski dim work or do I need the 18' since the cable on mine is 17.5'
Date Posted: September-23-2011 at 10:47pm
As Tim mentioned, the 6" longer cable will work. BUT, It's the stoke that's important!! Read his post again!!
Posted By: marmon77
Date Posted: September-26-2011 at 12:46am
I understood, I just thought Skidim carried the correct parts for the SN. I will call them and check tomorrow and if not I will be checking with a local dealer.
Date Posted: September-26-2011 at 11:23am
No, SkiDIM does not carry the CC-specific cables... thats a dealer item.
Posted By: marmon77
Date Posted: September-28-2011 at 5:18pm
Even the dealer doesn't have any at this time so.... I guess I'll be ordering from NautiqueParts.
Posted By: storm34
Date Posted: September-28-2011 at 7:11pm
I wouldn't worry about the steering wheel when you install. Worry about the throw first, then pop the cover off the wheel and adjust the wheel by loosening the nut behind the center cap.
Probably not the safest method, but Jody told me to get the boat to speed in a straight line with it finger tight and then lock the nut back down. Obviously do this in controlled conditions, not saturday on a July 4th weekend. I did this with our 96 and it's spot on now.
Date Posted: September-28-2011 at 7:34pm
Chris, that trick may only work on a R&P system... I dont believe a rotary system has that kind of flexibility.
Posted By: storm34
Date Posted: September-28-2011 at 9:04pm
Ah, didn't even think of that! I'l be curious to see how hard it is to get the wheel back center.
