how much anti freeze?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=24184
Printed Date: November-19-2024 at 11:46am
Topic: how much anti freeze?
Posted By: fishslayer
Subject: how much anti freeze?
Date Posted: November-21-2011 at 4:24pm
i have a 06 excalibur 330, i am wondering just how much anti-freeze it willl hold. i have added two gallons and it does not seem to fill.
also, you guys talk about pulling off the thermostat and filling the engine. i don't have the "traditional" thermostat housing. this engine has a plug just below the bracket where the two manifold hoses are attached and then large "coupler fitting" (for lack of a better word) i am guessing the thermostat is under that "fitting". i removed the plug below that fitting and looked in there, no liquid that i could see. of course i had already drained the engine by then, (im a bone head). it just dawned on me while i was typing. anyway, does three gallon sounds about right. aslo in looking at the levels of the manifolds and the plug there is no way the anti-freeze in filling the manifolds. fyi nothing is pour out the bottom of the boat either.
We all have the need for speed at some point in our lives.
Posted By: Hollywood
Date Posted: November-21-2011 at 6:10pm
It can take more than that, where are you filling from?
Date Posted: November-21-2011 at 6:19pm
i am filling from a plug just below the two hoses that go to the manifolds. i am guessing the plug is 1/2" square top. in is on top of the water pump and way above the impeller housing. i am pretty sure no a.f. in getting in the manifolds.
is that a way to post pix of my ingine on here to show you exactly what i am doing?
Date Posted: November-21-2011 at 6:24pm
There are a few picture posting methods. If those threads aren't "stuck" at the tops of the forums you'll have to search for them. You cannot push a liquid uphill, it won't go any higher than where you're filling from.
Read the engine manual, it has an antifreeze filling procedure.
Date Posted: November-21-2011 at 6:39pm
i have looked in the manual, but it is a genaric one that i had to steal of the net. i purchased the boat used and the old owner lost it. i have added 2 gallons, i will try a third and see if that brings it up the to top of the plug hole i am filling from.
thanks
Date Posted: November-21-2011 at 6:43pm
Filling to that hole still won't get any to the heads, intake or exhaust manifolds. There are PCM manuals available here and PlanetNautique.
Posted By: quinner
Date Posted: November-21-2011 at 6:46pm
Planet Nautique has the manuals on their site.
http://www.planetnautique.com/CorrectCraftManuals/2006/2006pcm.pdf - PCM Manual
http://www.planetnautique.com/CorrectCraftManuals/2006/2006196206.pdf - CC Manual
http://www.correctcraftfan.com/diaries/details.asp?ID=1143" rel="nofollow - Mi Bowt
