Should I paint the boat
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=24262
Printed Date: November-19-2024 at 9:35am
Topic: Should I paint the boat
Posted By: JohnnyT
Subject: Should I paint the boat
Date Posted: December-01-2011 at 1:14pm
I have a 1977 Ski Tique. Originaly I bought the boat for the motor, but after running the boat I realized I dont have the heart to butcher this boat. It is a cool boat. I want to restore it. The boat needs some body work, which I can do. Should I paint it? If so, what kind of paint. I have used Bright side in the past, but I want the best that I can do with this boat. Thanks JohnnyT
Date Posted: December-01-2011 at 1:21pm
No, dont paint it. Try to repair with gelcoat if you can. Post some pictures and we can help point you in the right direction.
Welcome to CCF! Where abouts in NY are you?
Date Posted: December-01-2011 at 2:18pm
Welcome to CCF! Where abouts in NY are you? |
I agree!
Posted By: JohnnyT
Date Posted: December-01-2011 at 3:13pm
I am in Scotia, NY. just outside of Albany.
Date Posted: December-01-2011 at 3:15pm
Do you boat on the Mohawk? Ive got family in the area.
Posted By: JohnnyT
Date Posted: December-01-2011 at 3:16pm
This is the best picture I have. The gelcoat is pretty faded and it has alot of scratches. What is the down side of painting it?
Date Posted: December-01-2011 at 3:20pm
It looks pretty good in the picture! To be clear, the yellow graphics are painted over the white gelcoat on the hull. Repainting the yellow would be appropriate if its showing a lot of wear. Painting the hull itself would not be ideal, as the original finish (gelcoat) is much thicker and harder than any kind of paint. Paint will therefore be easier to scratch or damage, and it cant be repaired easily like gel. Small cracks and chips in the gel can be spot repaired. Fading, oxidation and minor scratches can be removed by wetsanding and/or buffing.
Posted By: Jllogan
Date Posted: December-01-2011 at 3:28pm
I agree, paint is a last resort. I think you will be pleasantly surprised with the results of wetsanding and buffing. My boat was really bad when I got and the gel really came back nicely. Just invest in a good power buffer and some aspirin for your shoulder. Cheaper than painting too, if you buy good paint that is.
------------- http://correctcraftfan.com/diaries/details.asp?ID=5792&sort=&pagenum=1" rel="nofollow - 1986 Ski Nautique 2001
Date Posted: December-01-2011 at 3:30pm
I believe this is your boat?
http://correctcraftfan.com/forsale/details.asp?ID=3262 - Ski Tique in the diaries
Posted By: ny_nautique
Date Posted: December-01-2011 at 3:33pm
Johnny - is that the one that was at Mohawk Valley Marine? There is/was one there before Irene that was a total wreck inside. I have pics on my phone from it. There was no cover on it and I wonder what Irene did to it. Everything there was underwater, including where that boat was. Although yours looks cleaner than the one I saw, it is the same color scheme.
I would NOT paint it. You should be able to bring that back to life.
I'm in Latham and am currently working on my 84 Nautique. You can see some of what I'm doing http://correctcraftfan.com/forum/forum_posts.asp?TID=22083&title=1984-ski-nautique-project - here.
Edit: after looking at the link/pics Tim posted, that is obviously not the basket case that I saw at Mohawk Valley Marine.
------------- - Jeff 1999 Ski Nautique
Posted By: JohnnyT
Date Posted: December-01-2011 at 3:47pm
This boat came from Lake Placid. The inside needs some work, but it has no rips or tares. Everything on this boat is original. I would like the boat to look like new again. This boat is a vintage Hot Rod. I dont know anything about gel coat. That is why I thought about painting it.I will try sanding and buffing it. I lived on Old niskayuna road growing up.
Date Posted: December-01-2011 at 4:14pm
Gelcoat is great- you can bring a faded, worn finish back to life using basic hand tools and some elbow grease. If youre shooting for an original restoration (which I would applaud) then definitely dont consider paint.
Not sure if you saw my question- are you planning to use the boat on the Mohawk?
Date Posted: December-01-2011 at 4:34pm
Off topic... John I see you're an electrician. Are you looking for work? I'm trying to find a 2nd electrician to work out of my Colonie office doing lighting installs and retrofits.
Posted By: GottaSki
Date Posted: December-01-2011 at 4:57pm
How can ivory fade?
Wetsand 600 then 3m superduty its azz
River Rat to Mole
Date Posted: December-01-2011 at 5:02pm
John,
The usual question I ask is have you checked the condition of the stringers yet? I have a 77 and it needed a stringer job several years ago.
Welcome to CCfan.
I too would applaud an original restoration.
Don't wet sand the graphics off until you get a tracing. You'll need the tracing to have a paint mask made.
Posted By: dwcar
Date Posted: December-01-2011 at 10:44pm
Welcome to the site Johnny,
I like your attitude about wanting to save an old boat. The guys are right about the gel. It will shine like new with a little work.
------------- 83Ski
Posted By: Gary S
Date Posted: December-01-2011 at 11:17pm
Welcome John. Here are the standard pictures I post when someone asks about painting their boat. Wet sanded and buffed the original gel. You have nothing to lose by trying it first.
Posted By: vondy
Date Posted: December-02-2011 at 5:10pm
Guys has anyone used any type of electric sander for wet sanding? I know most use a DA but I don't have a compressor large enough to handle that. I thought they made an electric one but I'm probably wrong.
------------- http://correctcraftfan.com/diaries/details.asp?ID=4645&sort=&pagenum=1 - 69 Mustang HM
Date Posted: December-02-2011 at 5:20pm
vondy wrote:
I know most use a DA |
That would be news to me... I thought most people do it by hand (as I do). I know Sanity had decent luck with an electric D/A after she sprayed the gel on her Stang, though.
Posted By: Jllogan
Date Posted: December-02-2011 at 5:21pm
They do, I used a festool, but they are not cheap (you could buy a compressor and a DA for the price). Im not sure using an electric sander not meant for that is a good idea. I supposes it could work, wear rubber gloves.
Posted By: vondy
Date Posted: December-02-2011 at 5:44pm
TRBenj wrote:
That would be news to me... I thought most people do it by hand (as I do). I know Sanity had decent luck with an electric D/A after she sprayed the gel on her Stang, though. |
Guess I meant most people who use a machine rather than by hand use a DA.
I did a small sample by hand when I was winterizing. It looked great but took a lot of work just to do a 6x6 area with the first grit alone. I don't think I would have an arm left doing the whole boat by hand.
Festool has a wet sander? I'd love to have some Festool tools, but yeah, they are expensive.
Posted By: Jllogan
Date Posted: December-02-2011 at 6:10pm
vondy wrote:
Festool has a wet sander? I'd love to have some Festool tools, but yeah, they are expensive. |
Yes, most of their RO sanders can be used wet or dry. This is the setup I used. http://www.woodcraft.com/Product/2083126/34142/Festool-RO-125-FEQ-5-Dual-Mode-Rotex-Sander-with-TLoc--CT-36-Dust-Extractor-Package.aspx - festool
Posted By: Gary S
Date Posted: December-03-2011 at 12:47pm
I used a D/A because I'm lazy I started with 220 and ended up with 1000 I would stay away from electric, that and water don't mix.That festool is crazy money- how about using something made for that exact job? Smaller orbit than a da to keep swirling down.
http://www.tptools.com/Product.aspx?display_id=3292 - link
http://www.tptools.com/p/1541,204_Hutchins-Water-Bug-III-Wet-Sander.html - link
I think one of these is going on my Christmas list
Posted By: DrStevens
Date Posted: December-03-2011 at 7:12pm
Jonny T, sharp boat, good luck with you project. Gary S, those gel coat restorations photos are amazinng, one can see why all you experts recommend to redo/ sand the gel.
Date Posted: December-04-2011 at 11:56am
I use an electric! Maybe it's all those safety meetings you go to with the warnings about getting too high in that bucket that has you concerned! BTW, A GFI is a good idea on an electric but I never use one.
Posted By: Gary S
Date Posted: December-04-2011 at 12:15pm
Yea Pete I have seen sparks fly a few times over the years.Us low voltage techs do respect the Com Ed guys-
Posted By: eric lavine
Date Posted: December-04-2011 at 12:49pm
3m trizact, 3000 grit and soap and water, prefered to use on a Dynabrade DA, (made in the US) this will cut your buff time in half, trust me, when you pay someone to buff you dont want him on it all day
Posted By: Gary S
Date Posted: December-04-2011 at 12:56pm
Dr Stevens, I'm no expert I just followed what was done by the ones who are.Thats just one of the great things that Keith has brought together here.If your thinking of trying something just ask,someone has already done it.There are many of us that would not even attempted some of these projects,but the guys here are helpful and encourage you to do your best. I had tried buffing my boat many times,it just would not last.I was told you have to sand it which at first sounds wrong but it worked. Since it was so heavily abused it will never be perfect, but I'm very happy how it turned out.
Posted By: Got Tiques
Date Posted: December-04-2011 at 1:58pm
JohnnyT, I am also in Scotia, and ski on the Mohawk at JJ's with the US Water Ski Show Team. I also know Jeff Toro from this Site and work. Call me at 878-3545 and maybe we could hook up as I am always working on my CC's. I can offer help or learn from you. Thanks. Todd Benjamin
Posted By: JohnnyT
Date Posted: December-06-2011 at 11:56pm
Todd
Thanks for the invite. I will call you. Funny how small the world is. You worked with my father at GE. Does Toftegaard ring a bell?
Date Posted: December-07-2011 at 12:20am
John,
Your Dad, Gordie, spoke of you often. As you and my daughter are about the same age, we worked together and shared stories about our kids!!. My best regards to your Father.
So you are probably at the Lab and have gotten some info from Jeff Toro. He is a great resource and anal (In Caps) about his boat!! I taught him how to barefoot (briefly) on my '90 Ski and I can show you several older CC's that have a great gel coat shine without painting. Looking forward to meeting you.
Todd
Posted By: Maximal691
Date Posted: December-15-2011 at 3:18am
I'm up the road in Saratoga if you guys ever need a hand.
Posted By: JohnnyT
Date Posted: March-12-2012 at 3:26pm
I did not forget about you Todd. I just moved the boat into the shop. I needed to do some things to the shop first. The seats are out and I did alittle buffing on the hull.
