paneltronics indicator lights
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=24766
Printed Date: November-19-2024 at 9:49am
Topic: paneltronics indicator lights
Posted By: lakedog55
Subject: paneltronics indicator lights
Date Posted: February-01-2012 at 10:15pm
Hi installed new indicator lights, I wired them with one side to the breaker and other to a ground like the old ones, They worked but not sure if that is the proper way, My ignition breaker is heating up, Seems to be the coil wire, when coil is disconnected no heat.
Thanks Mike
Lakedog55
Date Posted: February-02-2012 at 8:16am
What's the total load on the breaker? Add the amps up and then use a DC rated amp meter to double check the calculated. The breaker isn't tripping is it?
Date Posted: February-02-2012 at 11:27am
Pete Thanks again,
Are you coming to the March reunion?
The indicator lights were wired to a ground but the new ones have no markings on them. They worked with one side wired to the switched side on the breaker and the other to a ground. I may have freaked out a bit when the wires heated up. It is not getting hot enough to burn my hand The only thing getting hot is coming from the coil back.
Thanks Mike
Lakedog55
Posted By: Bri892001
Date Posted: February-02-2012 at 1:03pm
When you say "coil" do you mean the ignition coil?
Date Posted: February-02-2012 at 6:26pm
yes, The heat is gone, new connections and ends, almost everywhere, still have some grnds to do and a few more going to the guages.
Lakedog55
