Water for Dripless Seal
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25052
Printed Date: November-19-2024 at 9:52am
Topic: Water for Dripless Seal
Posted By: BuffaloBFN
Subject: Water for Dripless Seal
Date Posted: March-01-2012 at 3:04pm
I've seen several places to pull this water. The most common seems to be from the 1" hose between the exhaust mani and thermostat. Has anyone decided on the best place? Would using a block drain be better or worse?
http://correctcraftfan.com/diaries/details.asp?ID=2331&sort=&pagenum=12&yrstart=1986&yrend=1990" rel="nofollow - 1988 BFN-sold
Date Posted: March-01-2012 at 3:24pm
Greg, did your kit come with instructions? I could have sworn the OJ we put in the BFN had a preference on where it went (high pressure vs. low pressure side of the RWP?). It looks like the PSS system doesnt care where it goes: http://www.shaftseal.com/en/about/installation_instructions - PSS Installation Instructions
If your kit doesnt have a preference, then just mount it wherever its easily accessible!
Date Posted: March-01-2012 at 4:23pm
So where does the OJ want to be?
Posted By: JoeinNY
Date Posted: March-01-2012 at 4:25pm
It is probably not super critical but mine is right off the discharge of the pump before it gets to the thermostat housing and is split to the engine/two exhaust manifolds. There it should allow the rest of the factory cooling system to essentially function as intended. IE not more or less water getting to one side or the other?
http://www.correctcraftfan.com/diaries/details.asp?ID=1477 - 1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Posted By: Jllogan
Date Posted: March-01-2012 at 4:31pm
Anyone know where i can get that T joint? Is that 3/8 hose that came with the kit? I have the seal but not the kit with the connector and hose. Any ideas on where to source those parts?
http://correctcraftfan.com/diaries/details.asp?ID=5792&sort=&pagenum=1" rel="nofollow - 1986 Ski Nautique 2001
Thanks Joe. Tim, I did get the PSS seal because I was also ordering a new cutless(cutlass?). Deep blue had the 6" cutlass and the seal. And yes, it has instructions. It offers 3 locations.
Date Posted: March-01-2012 at 4:40pm
Greg, I dont recall what the OJ instructions say. I dont have a good picture of where we installed it either. If youre concerned about it, then I would call OJ directly (1-800-359-9730) and see what they say. They'll probably put Eric Johnson on the line.
We ended up using our own tee, as I bought the kit second hand, and needed a 1-1/8" version instead of a 1". I used the same plastic tee that I use to connect the garden hose to. For a 351w, you would need a 1" barb x 1" barb x female NPT. The female NPT size can be whatever size you need to match the NPT male x 3/8" barb fitting. Probably 1/2" or 3/4". You can get them at Lowes.
Posted By: Jllogan
Date Posted: March-01-2012 at 4:43pm
bingo thanks tim! The dripless seal hose needs to be in front of the RWP right? Or it will just suck water from it instead of push it out.
Date Posted: March-01-2012 at 4:48pm
You had me curious enough to call Eric and ask... he confirmed that it should be plumbed to the outlet of the RWP (not the inlet) as you want the high pressure side to force water down through the seal and out the shaft log, not pull it in.
Posted By: Jllogan
Date Posted: March-01-2012 at 4:59pm
right, thats what I thought I was just thinking it would have been more convenient to put it back by the strainer. Then you coudl switch out the npt inlet on it and go from hose operation to ready for the water. Nothing is ever that easy.
Date Posted: March-01-2012 at 5:12pm
I wouldnt want that tee doing double duty... Having to break out a wrench and switch fittings around defeats the purpose of having the garden hose tee in the first place! Spend the extra $5 and get the extra tee and another 3' of 3/8" hose, it wont break the bank.
Posted By: Jllogan
Date Posted: March-01-2012 at 5:54pm
Its not the money I have five dollars (thats my wounded ego) . I just want to keep things tidy. Also shorter run of hose. I thought if it was more hidden maybe pete wouldnt notice its not original.
The point is moot anyway.
Date Posted: March-01-2012 at 6:13pm
Ha, I figured it probably wasnt a budget issue. I wouldnt worry so much about a little 3/8" hose being non-original, at least not considering the block color and valvecovers.
If you want to be fancy, you can pick up some color matched tubing from McMaster - http://www.mcmaster.com/#tubing/=gh6r71 . Try part number 5648K292.
Posted By: Jllogan
Date Posted: March-01-2012 at 6:31pm
yes!!!! fancy, thats my middle name tim I think I may have to get some of that, in red.
I thought he might not notice those things. The block color is fashioned after the later model PCM red valve covers, just kind of reverse color scheme. Yes under the hood is non original but that ok, Its a secret SHHH.
Posted By: M3Fan
Date Posted: March-01-2012 at 7:05pm
I ran it on the hose that feeds the port manifold. Plenty of pressure there. FWIW OJ said the seals don't really even need much, if any, cooling water. They run them on 6000+ RPM race boats with no problems.
I added a stop valve to control the flow of water. Handy for running in the driveway and for ensuring a little backpressure in the line so that the port manifold continues to be well-fed.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Date Posted: March-02-2012 at 10:38am
Thanks guys. I like the way Joe did his, but mine has a 1.25" hose there. I'll see what fittings I can find.
Posted By: SNobsessed
Date Posted: March-02-2012 at 10:47am
Greg, don't forget to post pictures!
Date Posted: March-02-2012 at 10:51am
Of where I get the water from?
Date Posted: March-02-2012 at 11:08am
Greg, I bought a box of tees like this:
http://www.ebay.com/itm/Lasco-PVC-Tee-1-1-4-Hose-1-1-4-and-1-2-Threads-/280758831491?hash=item415e87c983&item=280758831491&pt=Boat_Parts_Accessories_Gear&vxp=mtr - 1-1/4" tee on ebay
Then I bought a male 1/2" NPT x 3/8" barb from Mcmaster, along with the fancy colored hose I posted above.
Just in case your kit didnt come with these parts!
Date Posted: March-02-2012 at 1:39pm
Yuk it up buddy.
Tim is correct that the PSS seal doesn't come with install hardware, but I did find my 6" cutlass bearing. 2 shorter bearings may be as good or better, but that didn't seem right to me?
I also found the parts for this at Lowes. They wouldn't make a clean install though.
Date Posted: March-02-2012 at 1:47pm
Ha, Im not giving you a hard time- I had to buy mine after the fact as well (my OJ kit was for 1").
Date Posted: March-02-2012 at 9:28pm
Got me there, I should have figured it out for myself. It comes from Lake Lanier . . .
Date Posted: March-02-2012 at 9:32pm
Date Posted: March-03-2012 at 9:38am
Date Posted: March-03-2012 at 9:45am
Not to worry Eric, she's fine.
I went back to the beginning with a new crank. Gotta luv std/std...
Waiting on the T.
Date Posted: March-03-2012 at 11:36am
Greg, JK!
Your powerplant sure looks good!
Did you get any of the heavy weather yesterday?
Date Posted: March-03-2012 at 11:43am
Thanks you sir.
It woke me up early. Lots of 'show' and rain.
