Airguide pitots
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25333
Printed Date: November-19-2024 at 7:46am
Topic: Airguide pitots
Posted By: wetneck
Subject: Airguide pitots
Date Posted: March-24-2012 at 4:39pm
looks like i have a broken nipple on one pitot tube and not sure if i can find one like this locally, its the round base w/2 screws, airguide i assume ?? naut/parts has the faria, a 3 screw base/triangle that i use on my other boat but i dont want to add holes, sugestions where to buy ? thanks
Posted By: Waterdog
Date Posted: March-24-2012 at 5:09pm
Look in "Boat parts for sale" or White Lake Marine. I'm sure you can find the right one.
------------- - waterdog -
Posted By: wetneck
Date Posted: March-24-2012 at 5:35pm
yea white lake/ nautiqueparts didnt show it, ill keep looking
Posted By: 79TiqueRebuild
Date Posted: March-25-2012 at 12:54am
I picked up a tubing splice at the hardware store. Drilled out the old broken nipple. Ground off the barbs on one side of the splice then epoxied the splice in the pietot It works fine. Hope this helps, Monty
Posted By: Bri892001
Date Posted: March-25-2012 at 1:04pm
Yeah, they stopped making the original style for some reason. The only thing you can get is this http://www.skidim.com/prodinfo.asp?number=769B" rel="nofollow - Skidim New Style . Which has a different footprint and requires new holes to be drilled.
If 79TIiqueRebuild's idea can work for you, that's probably a better option.
Posted By: jimsport93
Date Posted: March-25-2012 at 1:12pm
I used the Skidim New Style listed above on my 93 Sport. Just used the two side holes. They fit pretty close to the original. Had to angle the screws in a little, but they work. Ground off the top edge of the new pitot removing the third hole (or just don't use it). Mounts fine and work very well. The black looks good too.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=2798 - 93 Sport Nautique
Date Posted: March-25-2012 at 1:19pm
jimsport93 wrote:
I used the Skidim New Style listed above on my 93 Sport. Just used the two side holes. They fit pretty close to the original. Had to angle the screws in a little, but they work. Ground off the top edge of the new pitot removing the third hole (or just don't use it). Mounts fine and work very well. The black looks good too. |
Ahh, ok. So you didn't have to drill new holes in your boat?
I read the part description more carefully, and it looks like you just drill the new pitots a little. That's better than I thought.
Date Posted: March-25-2012 at 1:51pm
Brian, no new holes required. That was a big plus! Hated to not "keep it original". One of my pitots was busted when I bought the boat back in 2007. Just tossed it (I was a new boat owner and did not know better)probably could have been repaired. However, those Skidim New Style did the trick. Besides looking good, they perform well and are self clearing (most of the time) if they get clogged.
Posted By: Keeganino
Date Posted: March-25-2012 at 2:02pm
The originals come up on Ebay pretty often if you have the patience to wait for a deal. It is pretty common to find NOS in the box with speedo, tubing and pitot.
------------- "working on these old boats may not be cost effective but as it shows its what it brings into your life that matters" -Roger
Date Posted: March-25-2012 at 2:04pm
Here is one for http://www.ebay.com/itm/VINTAGE-AIRGUIDE-SERIES-10-SEA-SPEED-1020-MARINE-SPEEDOMETER-SET-OLD-STOCK-MIB-/370598310774?pt=Boat_Parts_Accessories_Gear&hash=item5649617376&vxp=mtr" rel="nofollow - $25
Date Posted: March-25-2012 at 2:14pm
That is what I should have done. Maybe next time.
Posted By: wetneck
Date Posted: March-25-2012 at 2:35pm
does anyone know if the skidim footprint is similar to the faria or teleflex are they are much easier acquired ??
Date Posted: March-25-2012 at 5:53pm
wetneck wrote:
does anyone know if the skidim footprint is similar to the faria or teleflex are they are much easier acquired ?? |
I guess all are variations. None are exact Airguide replacements. It looks like Nautiqueparts is saying that their white ones require no modification if just using the bottom two holes. Looks like the holes are more of a groove than a hole. I guess drilling the Skidim Pitots a little is like creating a groove.
It just comes down to what you prefer. I like the idea of the non-clogging that Skidim has. If you click on the image, it gives other images that show how to drill the plastic on the pitot (not the boat) to get it to work.
