Sanding Gelcoat
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25337
Printed Date: November-19-2024 at 5:43am
Topic: Sanding Gelcoat
Posted By: nautique78
Subject: Sanding Gelcoat
Date Posted: March-24-2012 at 9:23pm
Has anyone every noticed a brownish/gray color of gelcoat when they have sanded a white hull. Im sanding my 76 Tique and trying to get the boat back to original white color from years of sun and Im having trouble getting the gelcoat to all blend the same color. I know the boat has never been painted or regelcoated, but its almost as if the gelcoat faded gray at first and then brownish color more recently. Hoping others have had this same problem and maybe someone may have advice on what they did.
Nautique78
nautique78
56Hot Rod Special
70Mustang
70Skier
76Tique
78Nautique
79Nautique
92Nautique
98Nautique
Posted By: SNobsessed
Date Posted: March-25-2012 at 1:06am
yes, mine has a yellow-brown tinge where it has not been sanded. It goes pretty deep too.
Posted By: Keeganino
Date Posted: March-25-2012 at 2:14pm
That is a good looking boat! You have to be fairly aggressive to remove a color change like that. What grit did you start with? When I did the skier it was kind of scary at first because I used some pretty rough stuff. I want to say around 380 or maybe even a little rougher to remove some of the deeper scratches. It looked hazy until it got buffed, and what a difference!
Posted By: reftech
Date Posted: March-25-2012 at 2:40pm
I had the same issue on mine and started with 400 grit and sanded aggressively on it.my browning went deep as well and I probably could've even used 320 grit.nonetheless after working my way up to 1000 grit and buffing it turned out nicely.I'm sure yours will turn out if u keep hitting it.
Posted By: NAUTIQUEjunky
Date Posted: March-25-2012 at 3:03pm
What your seeing is the nasty water and grime that has embedded itself in the gel coat over the years especially on a 76 model. It won't be as bad as you sand to the cleaner gel.
1977 MasterCraft Stars&Stripes
1994 Ski Nautique
2000 Super Air Nautique
1986 Ski Nautique 2001
1999 Sport Nautique gt40 current
Date Posted: March-25-2012 at 3:20pm
Yes!
Posted By: Hawktique
Date Posted: April-20-2012 at 2:53pm
Marty, I went through the whole process on my '90, and a neighbors boat as well. Let me know if you need any help. I'm up in Marion now. Sold the '90 after the dam broke. I gotta love your new rig, almost identical to our old Tique from Delhi.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=17166&KW=sanding&title=sanding-and-buffing" rel="nofollow - '90 restore
"A Veteran is someone who at one point in his life, wrote a blank check made payable to: 'The United States of America,' for an amount of 'up to, and including his life." Semper Fi
