high revs on new 200
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25372
Printed Date: January-11-2025 at 5:40pm
Topic: high revs on new 200
Posted By: laurie
Subject: high revs on new 200
Date Posted: March-27-2012 at 1:56am
guys
breaking in my 200
at 32mph she is doing 3800 rpm.....is this normal
i ordered stock prop. Can the prop be put on the wrong way around?? my mech fitted it whilst doing the prep
cheers for help
laurie
laurie
Posted By: quinner
Date Posted: March-27-2012 at 3:46am
Do you know if your prop is the 422? Do you have the Excalibur 343?
The 200 hull is definitely slower then your 206 would be.
http://www.correctcraftfan.com/diaries/details.asp?ID=1143" rel="nofollow - Mi Bowt
Posted By: laurie
Date Posted: March-27-2012 at 4:43am
yes i have the 343 PCM
I thought the stock prop was someting like 1843??
laurie
Posted By: GlassSeeker
Date Posted: March-27-2012 at 6:01am
no can't be on backwards
This is the life
Posted By: Fl Inboards
Date Posted: March-27-2012 at 8:55am
Yes that is about right with the 200 and a ex 343. I have a 200 with a 6 liter mine runs a lot lower rpm's even with the stock 654. suggestion as long as you are not jumping or trying to barefoot is to install a 422 ACME. currently I run a OJ on mine and run slightly over 3700 at 34 with a shortline skier, would recommend an OJ however at this time their is not a size that will efficiently work with the 343
Posted By: laurie
Date Posted: March-27-2012 at 9:21am
thanks guys
laurie
Date Posted: March-27-2012 at 12:13pm
I think youve already gotten an answer to your question, but the only thing not mentioned is what the "stock" prop is on an Excal powered 200. It is not the 422 (12.5x15.5) that came on the GT40 and Excal powered '01-09 Ski Nautique/196/206. The 654 (12.5x15) that Jody mentioned is now stock on the 6.0L 200 only, I think... the Excal powered boats that Ive seen have all had the 1868 (12.5x14.25). The lower pitch explains the higher revs. It would be interesting to see how the boat performed with the 654, as Jody reports the 6.0L does well with the 422 and OJ equivalent (428).
