Lift Ring gasket
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25373
Printed Date: November-19-2024 at 6:38am
Topic: Lift Ring gasket
Posted By: Foot_Fungus
Subject: Lift Ring gasket
Date Posted: March-27-2012 at 11:34am
Was going over the boat for my initial "must fix" parts list and noticed there is a 1/4-1/2 inch gap between the front lift ring and the hull, which I'm guessing is where a gasket should go? If that is the case where on earth would I find one of those at? Checked skidim and such and didnt see anything close.
Date Posted: March-27-2012 at 11:39am
I've never seen a gasket. Get under the bow and adjust the ring closer to the deck. It will also give you the opportunity to inspect the hardware and attachment point.
Date Posted: March-27-2012 at 11:52am
Ive never seen a gasket either. My Skier has gap between the flange and the deck... its solid though. I figure the boat was probably built on a Friday!
Posted By: Swatkinz
Date Posted: March-27-2012 at 12:46pm
should there be some type of silicone b/w the gel of the deck and the ring? I'd sure be careful to ensure that ring tightened up evenly.
------------- Steve 2011 Sport/Air 200 Excalibur 343 2017 Boatmate Tandem Axle Trailer
Former Malibu owner (07, 09)
Date Posted: March-27-2012 at 12:58pm
Steve, I suggest no caulking btween the deck and eyes. You do get some hull flexing when lifting and you want the lifting point to float. With cauking you may transfer stress into the deck.
Date Posted: March-27-2012 at 3:24pm
eh, just seems like a great place for water to come in. I may fab up some kind of foam gasket ring to make me fee better.
Posted By: Keeganino
Date Posted: March-27-2012 at 4:21pm
I know my local Ace has an array of different rubber, neoprene and cork gaskets. Cannot remember what I did on the Skier, but I probably sealed it with 5200. Will take a look when I get home. I do not use the lift hooks. Maybe once I get that lake house with the boat house.
------------- "working on these old boats may not be cost effective but as it shows its what it brings into your life that matters" -Roger
