TRANS FLUID LEVEL HELP
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25554
Printed Date: November-19-2024 at 4:48am
Topic: TRANS FLUID LEVEL HELP
Posted By: TB..337
Subject: TRANS FLUID LEVEL HELP
Date Posted: April-12-2012 at 12:30am
CAN ANYONE TELL ME HOW FULL TO FILL THE TRANS. FLUID 1980 SN .THE DIP STICK HAS JUST ONE LINE ACROSS IT . DO I FILL TO THE LINE OR BELOW IT ?
Posted By: levinmark
Date Posted: April-12-2012 at 12:37am
what kind of tranny do you have in your 80'. Most people will tell you to put back in what you pulled out during the extraction, if your changing the fluid. More will be along with some suggestions
------------- levin
Posted By: TB..337
Date Posted: April-12-2012 at 1:08am
BORG WARNER VELVET DRIVE. CAN I JUST ADD TO IT OR DO I HAVE TO DRAIN IT THEN REFIL. ONLY HAD THE BOAT OUT ONCE AN IN NEUTRAL OPON STARTING IT WOULD PULL FORWARD . TOOK OFF FINE THEN STARTED SLIPPING SO I LIMPED IT BACK TO THE DOCK. CHECKED FLUID AN LESS THAN HALF INCH ON THE STIKE. SO WHAT U THINK ON HOW CLOSE TO THE LINE SHOULD I FILL.
Posted By: sweet77
Date Posted: April-12-2012 at 1:49am
how long did you run the boat before it started slipping??? and fill it to the line with the labeled trans fluid probably a dextron lll maybe?? and you should be able to fill it up if you have not burned the clutches in the trans. if you ran it for a while, while they were slipping a rebuild will probably be in order. Eric will be along to help a little more
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=5528&sort=&pagenum=1" rel="nofollow - 76 Nautique
"If you do what you always did,You'll get what you always got!"
"An empty wagon makes t
Posted By: TB..337
Date Posted: April-12-2012 at 2:48am
GEEEZZZZ.YEAH I HOPE I DIDNT BURN IT UP. I WENT ABOUT HALF A MILE IF THAT WHEN I FELT IT SLIP. THEN BABIED IT BACK TO DOCK. WOULD THAT BE ENOUGH TO BURN IT IF THE FLUID WAS REAL LOW?
Posted By: sweet77
Date Posted: April-12-2012 at 3:20am
maybe not fill it up and try it out
Posted By: OverMyHead
Date Posted: April-12-2012 at 8:33am
Terry, Please turn off the cap lock on your computer. Typing in all capitals is considered yelling when online, although I can understand where potentially burning up your tranny might make you feel like yelling. . Good luck, I am not much help with the rest. I fill to but not past the line just like oil in my car.
------------- For thousands of years men have felt the irresistible urge to go to sea, and many of them died. Things got better after they invented boats. 1987 Ski Nautique
Posted By: eric lavine
Date Posted: April-12-2012 at 8:36am
you may have caught it in time, it would drag a touch or have a dirty neutral if you slipped it under a heavy load
Date Posted: April-12-2012 at 8:46am
eric lavine wrote:
you may have caught it in time, it would drag a touch or have a dirty neutral if you slipped it under a heavy load |
Eric, Terry mentioned the dirty neutral above as well in his previous threads on the same slipping subject. From his description, it's so "dirty" that it pushes the boat when it's in the water.
Terry, As suggested in your other thread with the dirty neutral and the slipping, I feel it's time for a rebuild. The dirty neutral is the indicator of warped clutch plates.
The fluid level is to the line when COLD.
BTW, it's always best to keep the same subject in the same thread. That way, we won't get confused!
Posted By: TB..337
Date Posted: April-13-2012 at 1:39am
Thanks for the help. Sounds like im going to be pulling the tranny soon. Iv never done it before so any advice would help. Once I get it out an shipped how long should I expect the turn around to take? What should i expect to pay? (ballpark)
Date Posted: April-13-2012 at 8:58am
Terry, Check out http://www.correctcraftfan.com/forum/forum_posts.asp?TID=25526&KW=&PID=326952&title=trans-slipping#326952" rel="nofollow - your other thread for the cost. This is a good example of keeping the same subject in the same thread! Give FFM a call for the turn around time. You looked at their web site - the phone # is on it.
Removing the trans is pretty easy and straight forward. If you don't have a means of hoisting the aft end of the engine, a bottle jack under each manifold works great. The prop shaft coupling is disconnected as well as the aft engine mounts. Front mounts are loosened and the engine is tilted. Don't forget to put a new dampner plate on with the rebuilt trans. You will need to do an alignment when it's all back together. In the "new" section of the forums, there is a http://www.correctcraftfan.com/forum/forum_posts.asp?TID=21279&title=shaft-strut-alignment-video" rel="nofollow - alignment vidio .
Posted By: lakedog55
Date Posted: April-13-2012 at 9:49am
Does it push right when you fire it up or does it keep pushing? I believe they all push a little upon starting. Mostly from the sudden rush of exhaust and water. Thanks Mike
------------- Lakedog55
Date Posted: April-13-2012 at 10:00am
Mike, I really feel Terry is in need of a rebuild. It's the dirty neutral but even more convincing is the slipping he's getting. Both point to warped clutch plates.
Date Posted: April-13-2012 at 12:27pm
Pete, I agree with you. If it is slipping and has good fluid with the right amount then the tranny needs some love. Looking at his thread I was not sure how many of these boats he has started, Everyone I ever started all push a little whn fired up. Mike
Date Posted: April-13-2012 at 12:54pm
Mike, I do agree that the exhaust does push a little when the engine is started.
Posted By: TB..337
Date Posted: April-13-2012 at 8:51pm
Thanks guys. called FFM for turn around time. About two weeks. WOW FAST. Im going to top off the fluid.Try it out again. Update yal if i pull it . Sure I will have more questions. Going to take some pics of my boat soon . Thanks again
Posted By: TB..337
Date Posted: April-23-2012 at 2:58am
Hey guys I filled with dex an ran the boat around for about an hour. No slipping. reverse works but neutral still seems like it wants to pull. Like if i have it running at the dock to warm up I cant hold on to the dock because it wants to pull in neutral. Is that because the tranny is about to go? (dirty neutral) I would hope to make it through the summer before I pull it.
Date Posted: April-23-2012 at 3:23am
Does the dirty neutral remain after it warms up? My 87 has had dirty neutral problems for years but it goes away when the trans fluid warms up, and I can idle at a dock with minimal effort to hold the boat in place.
Posted By: TB..337
Date Posted: April-23-2012 at 3:33am
Im sure it had time to warm up I ran it about an hour . i couldnt hold it while my brother went to back the trailer in .
Date Posted: April-23-2012 at 9:35am
TB..337 wrote:
Im sure it had time to warm up I ran it about an hour . i couldnt hold it while my brother went to back the trailer in . | If it's that bad, you sure have warped clutch plates from slipping. I'd sure pull the trans and get it off to FFM. Is there any fluid leakage?
Posted By: TB..337
Date Posted: April-23-2012 at 11:07pm
No fluid leaking. it was a QT low when I bought it.Ran it once thats when it started slipping. I put a QT of fluid in stopped the slip but neutral is still funky like I said.
