Tranny Fluid Temp?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25734
Printed Date: November-19-2024 at 4:19am
Topic: Tranny Fluid Temp?
Posted By: HatterBee
Subject: Tranny Fluid Temp?
Date Posted: April-26-2012 at 1:41am
Hey guys I am thinking of adding a fluid temp sensor in the tranny while I have it out and redoing my gauges and wiring. However, I have come to a crossroads of sorts to my plan.
Do I install the sensor in the line going to the exchanger, or the line coming from the exchanger?
I can think advantages of both and would like to hear your thoughts and experiences if you have done something similar.
------------- 1977 Ski Nautique Under Re-construction
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=25004&title=1977-ski-nautique-rebuild" rel="nofollow - My Rebuild Thread
Posted By: DrCC
Date Posted: April-26-2012 at 1:59am
Mine is forward and to the right of the return line on the transmission.
Date Posted: April-26-2012 at 2:22am
You talking about on top of the tranny directly beside the return? I do have a port there with an allen headed plug in it. It looks pretty rusty not sure it will come out easily, but I might try that.
Do have a complete temp sensor with gauge or just a high temp switch?
Posted By: DrCC
Date Posted: April-26-2012 at 2:44am
Yes, The Alan plug next to the return line.
No guage. Sender to alarm buzzer.
It's actually factory from '74.
Posted By: eric lavine
Date Posted: April-26-2012 at 8:28am
normally the sender does go to the plug next to the cooler out line on top of the trans
Date Posted: April-26-2012 at 11:19am
Thanks, I was also just looking at the alarm sensor.
Date Posted: April-26-2012 at 11:41am
What temp does your alarm go off? Looking at sensors now and I have found 195, 230 and 235
Posted By: DrCC
Date Posted: April-26-2012 at 12:46pm
Since I've had it, the alarm has never gone off.
