Screwing into new wood/ Stringers
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=25939
Printed Date: November-19-2024 at 3:24am
Topic: Screwing into new wood/ Stringers
Posted By: Big Pappa
Subject: Screwing into new wood/ Stringers
Date Posted: May-10-2012 at 7:14pm
So last night I cut my bilge access hole in the front in front of the ski pole. That got me to thinking about how I wanted to mount the cover, seat frames, latches, hinges, wire zip ties in the bilge.
From the factory they were all screwed in but I am a little worried after all this work water proofing (As good as I can anyhow)to just drill a hole and screw into it.
What does everyone else do? Drill a pilot hole, CPES the holes a couple of times, let dry, 5200 the holes and run the screw in? Are there any other ways out there?
I have been working on this thing for long enough that I do not want water to have an option to get back under the floor or in the stringers if at any way possible.
------------- http://bit.ly/Mghpvx" rel="nofollow - Big Pappa
http://bit.ly/L4zRW0" rel="nofollow - My Project
Posted By: gun-driver
Date Posted: May-10-2012 at 7:33pm
I counter sunk the lip of the battery box and used thick epoxy to glue it down. Unfortunately, with the driver seat and the other seats for that matter it’s pretty hard to seal the screws due to the carpet. So that ends up being the nature of the beast. As for the fuel lines and wiring harness I used the square mount zip ties glued with a hot glue gun. http://www.lowes.com/pd_292685-1781-45-1MBUVL_0__?productId=3128405&Ntt=zip+ties&pl=1¤tURL=%2Fpl__0__s%3FNtt%3Dzip%2Bties%26page%3D2&facetInfo=" rel="nofollow - http://www.lowes.com/pd_292685-1781-45-1MBUVL_0__?productId=3128405&Ntt=zip+ties&pl=1¤tURL=%2Fpl__0__s%3FNtt%3Dzip%2Bties%26page%3D2&facetInfo=
Date Posted: May-10-2012 at 7:37pm
Big Pappa wrote:
What does everyone else do? Drill a pilot hole, CPES the holes a couple of times, let dry, 5200 the holes and run the screw in? Are there any other ways out there? | Yes, and I'd inject some epoxy after the CPES as well. If it plugs up your pilot hole, drill it again.
Date Posted: May-10-2012 at 7:52pm
8122pbrainard wrote:
Big Pappa wrote:
What does everyone else do? Drill a pilot hole, CPES the holes a couple of times, let dry, 5200 the holes and run the screw in? Are there any other ways out there? | Yes, and I'd inject some epoxy after the CPES as well. If it plugs up your pilot hole, drill it again. |
It would be pretty hard to do that for the seat bases and latches without making a mess of the carpet. Not to say it can't be done but I would hate to mess up my new carpet over some little screw holes.
Date Posted: May-10-2012 at 9:07pm
gun-driver wrote:
It would be pretty hard to do that for the seat bases and latches without making a mess of the carpet. Not to say it can't be done but I would hate to mess up my new carpet over some little screw holes. |
With the 5200, just put it on the screw threads.
Date Posted: May-11-2012 at 1:35pm
I like this Idea if hot gluing these mounts on and zip tying to them. I think I am going to do that as well. How has it been holding up for you?
As for the rest of the holes I guess I will just waterproof them the best I can and hope that is enough.
Posted By: TX Foilhead
Date Posted: May-12-2012 at 5:31pm
Don't know if this works or not, it would be easy to try though. Drill the hole, fill it with epoxy and then put a dab of grease or vasaline on the screw before you put it in. Supposedly that keeps the epoxy from attaching to the screw so it can be removed and coats the hole with epoxy at the same time.
Date Posted: May-12-2012 at 7:11pm
TX Foilhead wrote:
Don't know if this works or not, it would be easy to try though. Drill the hole, fill it with epoxy and then put a dab of grease or vasaline on the screw before you put it in. Supposedly that keeps the epoxy from attaching to the screw so it can be removed and coats the hole with epoxy at the same time. | Don, I don't feel this method is a good idea. The grease will contaminate the epoxy. It's more of a "back yard" method than anything.
Date Posted: May-12-2012 at 8:38pm
You're probably right, I don't have anything to test it on or with right now, but it would be easy enough for someone who's already working on something to giving a try. I would worry most that the screw would be stuck. An alternative test would be a hole larger that the screw so you could place it without turning it and mixing the epoxy and grease. That one might only work on floors otherwise the epoxy would run out.
Date Posted: May-12-2012 at 9:22pm
Don, Don't bother with the testing. The Gougeon brothers have already done it. For mechanical fastening with screws or even threaded fasteners, they recommend boring a hole 3 to 4 times the diameter of the fastener and filling it with epoxy using a high strength filler. Then, after curing, drill it for the pilot hole or in the case of a threaded fastener, drill the correct tap drill size and tap the epoxy.
Date Posted: May-12-2012 at 9:40pm
That would take care of it. I'm not planning on needing to do that anytime soon or possibly ever again. The boat with no rot keeps me plenty busy with no need to try that and I don't see the time or the wife agreeing to another project boat. We were happy though to run into our old boat last weekend and 5 years later she still looks as good as the day I finished her.
